powered antenna
Old Aug 23, 2013 | 10:25 AM
glider69's Avatar
glider69
Default powered antenna
I was just wondering if anyone else doesn't get good reception with there powered antenna mounted inside the fairing. I just put a cheaper one in from advanced auto. Im wondering if the dakota digital or any others are worth the money and if there's a better spot for mounting that will help too. Thanks in advance
Old Aug 23, 2013 | 10:46 AM
mkguitar's Avatar
mkguitar
a powered antenna will amplify radio signal and noise equally.
so if you are trying to hear music through a bunch of static a powered antenna will not help with that.
true:
antennas work best when perpendicular to the ground
antenna length tunes the antenna for the frequency range- "cutting" an antenna de-tunes it.
you may find that a rubber stubby is concealed enough.
that is what I have ended up with after testing many systems on multiple bikes over the years, am, wb and fm.
with the tourpak on I can still use the stubby or use a full length stock style antenna
mike
Old Aug 23, 2013 | 11:33 AM
Hughey79's Avatar
Hughey79
I tried the shorty antenna and then switch to the powered one inside the fairing. However I did not want to purchase Harley's version due to cost. I see now they have a newer version even but its still too pricey for me.
So what I did after some research on here was to go to O'Reilly auto parts store or the like and bought the same thing but its made by Metra I think. Works the exact same and cost me a whopping $17 something.
It has worked as good as can be for a hidden antenna. Nothing is going to be as strong as the stock whip though. Local radio is perfect but out in the open country it gets weaker.
Old Aug 23, 2013 | 12:49 PM
nvsteve's Avatar
nvsteve
Ditto for me with the Metra. Easy to install as there are two unused wires
(hot and ground) in the wiring harness near the headlight.
oakspeed
Audio Systems
Sep 13, 2016 08:38 AM
Mcarso1
2014-2024 Touring Models
16
Sep 18, 2014 07:44 AM
ConfuciusSay
Feb 22, 2014 06:42 PM
bgdv1
Audio Systems
Sep 15, 2011 01:24 PM
THABULL
Mar 18, 2008 09:04 AM
