Plasma Rods
Old Sep 6, 2013 | 01:41 PM
Glider13's Avatar
Glider13
Stage IV
Default Plasma Rods
Looking for any wiring tip for a 2013 RGC FLTRX with the fender tip light.
Old Sep 6, 2013 | 01:58 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
If just run/brake, there's a connector under the left side cover at the rear.
Hang on..... I'm looking for more info............
I'm back..... found it.
You wire them up the same way as the center aux light
http://www.harley-davidson.com/en_US...ts/-J05374.pdf
Figure 1 shows the plug you need to access to tie in the run/brake for the Plasma Rods.
And alternate way is to tie into the ACC plug under the seat for run/brake. But that requires more wire, and a longer run.
aviscomi
Oct 1, 2017 08:37 AM
BigWaterJim
Electrical/Lighting/Alarm
May 10, 2015 09:33 AM
rebbe18
Oct 16, 2013 05:21 PM
pipedog
EVO
May 7, 2013 02:15 PM
Bullitt59
Mar 1, 2013 09:19 PM
