Voltage gauge issue
Old Sep 8, 2013 | 04:07 PM
ep120794's Avatar
ep120794
Default Voltage gauge issue
On my 2012 Road Glide my voltage gauge has been moving between 14 and 11. Bike is becoming hard to start. What should I look for?
Old Sep 8, 2013 | 04:10 PM
Stiggy's Avatar
Stiggy
11 at idle and 14 moving down the road? It's normal.
Check your battery.
( If its something different than that please advise!)
Old Sep 8, 2013 | 04:16 PM
mkguitar's Avatar
mkguitar
the in dash voltmeter is notoriously inaccurate- confirm readings with a meter at the battery ( or tender plug if you have one)
slow crank? smartest to check and clean the battery cable connections...on both ends of each cable.
you could charge the battery with a charger ( not a tender) and load test at autozone.
while you are at it, loosen the starter bolts and retighten to ensure a good ground
these basic steps are free- and once you know that this is good- you can better find a fault if it still exists.
you can look at the charging system, if you know how to use a meter, this is easy
low voltage from a bad battery can load the charging system abnormally and damage it.
low voltage may also screw up the starter solenoid.
mike
Old Sep 8, 2013 | 04:29 PM
ep120794's Avatar
ep120794
It is going down to 11 on the gauge at 70 mph and 3K RPM's. No aftermarket stero. Just slip ons and Cobra Power Pro.
Old Sep 8, 2013 | 05:18 PM
dukdog's Avatar
dukdog
Check your stator output . I had the same problem and found the stator was fried. Not too difficult a replacement job except running the wire through the case. Search for the thread in the electrical section that tells how to check your charging system.
Old Sep 8, 2013 | 05:22 PM
Stiggy's Avatar
Stiggy
If its sometimes 14 and sometimes 11 at 3,000 rpm, if you don't have a loose connection then I would suspect the regulator. (Stators don't break "sometimes".)
Old Sep 8, 2013 | 07:47 PM
Rooster37's Avatar
Rooster37
2012 had a voltage regulator recall. My 2012 had the exact same issue. Take it in and see if it is one of the bad ones. I gave them hell about my battery and made them replace it too.
Old Sep 8, 2013 | 08:03 PM
Nute's Avatar
Nute
Chances are very good it's your VR. Possibly your alternator, but most likely your VR. 2012; I believe you are still on warranty. I would suggest you take it to a dealer and get the VR checked out. You actually can damage your battery and/or your alternator running with a bad VR not to mention that getting stranded is a distinct possibility. If I'm not mistaken HD had a run of bad VR's.
Even if you are off warranty get it checked out especially if you don't know what you are doing electrically.
Old Sep 8, 2013 | 08:56 PM
geezer glide 56's Avatar
geezer glide 56
2012 was a bad year for voltage regulators...Harley had a bad batch of them.
Old Sep 8, 2013 | 09:56 PM
bill from tn's Avatar
bill from tn
True.
Mine went out at 300 miles. Heat will make a bad one act up. The recall stated that they would replace any of the bad lot thru June 11, 2014, independent of the warranty status of the bike.
Check with your dealer and remind him of the recall on a large batch of 2012 regulators.
https://app.box.com/s/d3794df7ba0c20cd178e
should be all the info you need to check to see if yours is in the affected batch.
You will probably trigger a voltage discharge light and a check engine light if you have a bad voltage regulator.
Davy Pig
Milwaukee Eight (M8)
Jun 21, 2019 04:30 PM
Bagger G
Electrical/Lighting/Alarm
Oct 16, 2017 02:26 PM
c50plus
May 12, 2014 08:09 AM
vickers1
Aug 1, 2013 09:48 AM
TennesseeEG
Apr 5, 2012 09:34 PM
