Starter issue???
Old Apr 22, 2014 | 11:53 AM
  #31
mkguitar's Avatar
mkguitar
Originally Posted by Bingee
2008 thru 2011 103's except for police models.
hmm had a 2011 FLHTK 103 with ACR's, I didn't know that the other 103's didn't have (?), my parts book shows acrs for all the 2011 103 motors
and as the 103 became std in 2012 they all had acr's
Mike
Old Apr 22, 2014 | 04:01 PM
  #32
kitehog's Avatar
kitehog
Thanks Bingee but it was the compensator. I replaced it this winter and been running it pretty hard this spring with no issues
Old Apr 22, 2014 | 04:16 PM
  #33
Just-Jeff's Avatar
Just-Jeff
Kite, I just went through this. The bike starts great cold but when hot, WOW that sound about kills ya!!!! It's the starter drive, the piece that pops out of your starter. The 2007 / 2008 had issues with this kind of thing.
The big thing is if your motor has had any work done to it. Have you or other owners bumped it to the 103 / 106, or even more? After fixing the starter drive you might also want to look into a decompression release. The current 103 have a decompression built into em so they don't burn up the starter drives.
Hope this helps, parts are only $100.
Old Apr 22, 2014 | 06:52 PM
  #34
btsom's Avatar
btsom
The first hint that the compensator is weak is the hard bang or crack when hitting the starter. That is the compensator going full travel and slamming into the stops. That happening over and over will destroy the starter drive, actually the sprag clutch in the starter drive. The sprag clutch slipping is most likely the grinding sound you are hearing. I have had an Allballs starter drive for over 4 years and 47,000 miles (installed at the same time as the SE compensator) and have had flawless operation since the change. 2008 Road King, stock 96 now with over 62,000 miles.
Old Apr 22, 2014 | 07:09 PM
  #35
Just-Jeff's Avatar
Just-Jeff
Guess I should have read the WHOLE thread!!! Glad you were able to fix it.
Old Apr 23, 2014 | 05:11 PM
  #36
Bingee's Avatar
Bingee
Mike
True.The 2011's with the optional factory 103's did have ACR's installed.
Summers420us
EVO
30
Feb 22, 2023 03:10 PM
marktruckee
EVO
Feb 24, 2016 07:20 AM
Donn 86 flhtc
Mar 4, 2015 07:42 PM
TimLScheffer
Sep 3, 2013 09:48 AM
wbogley
Shovelhead
Nov 28, 2007 09:42 PM
