Need a load equalizer for 1 LED bulb in tailight ???
Old Sep 16, 2013 | 11:37 AM
WOLFE1584's Avatar
WOLFE1584
Default Need a load equalizer for 1 LED bulb in tailight ???
07 Electraglide - replacing bulb in tailight. Can I use a 3157 LED instead of stock 3157 incandesent bulb without using a load equalizer ? I thought LED technology uses less energy than incandesent. Maybe this is the reason for a load equalizer ? But for 1 bulb ? Please set me straight.
Old Sep 16, 2013 | 03:38 PM
dougm1950's Avatar
dougm1950
Load Equalizers are needed for LED turn signals to keep them from flashing really fast as they are designed to do indicating a burned out incandescent bulb (ECM thing). Not required for tail lights no matter how many LEDs are in it.
Old Sep 16, 2013 | 04:44 PM
grbrown's Avatar
grbrown
No you don't need any equalizer for a single bulb. The equalizer is only necessary on bikes when replacing the incandescent bulbs with LEDs, to fool the flasher unit into thinking it still has normal bulbs. The flasher unit is designed for the higher electrical loads of filament bulbs, not the low loads of LED bulbs.
Old Sep 16, 2013 | 05:06 PM
Bruce00's Avatar
Bruce00
The simple answer is.................NO
Old Sep 16, 2013 | 06:31 PM
PhatTerry's Avatar
PhatTerry
Generally taillights and headlights don't need a load equalizer. Typically only lights with flashers need a load equalizer as the flasher depends on a load to work properly.
Old Sep 16, 2013 | 07:20 PM
Skip's Avatar
Skip
If I was to add a 2nd set of turnsignals that were LED and tap the wire from the existing signals [which I am keeping], would I then need to add an equalizer for the LED's?
Old Sep 16, 2013 | 08:20 PM
skratch's Avatar
skratch
not if you are keeping the original incandescent turn signals connected.
Old Sep 17, 2013 | 11:01 AM
PhatTerry's Avatar
PhatTerry
You will not as your original signals will be providing the load that your flasher needs. You are actually increasing your load slightly which is okay. It's when you decrease the load things get strange. LED's draw very little load which is what causes the the issue when swapping the lights out.
Hope that makes things a little more understandable.
Old Sep 17, 2013 | 12:27 PM
dyna07custom's Avatar
dyna07custom
and I simply agree with him
Old Sep 17, 2013 | 07:20 PM
Skip's Avatar
Skip
Skratch and PhatTerry - thanks, that' what I thought but wanted verification from someone that knew
wildfire
Sep 16, 2016 07:14 PM
Wideglide_Steve
Aug 7, 2016 09:01 PM
paulies 07
Mar 13, 2011 12:50 AM
CREEPSHOW
Jan 13, 2008 10:03 AM
brendajmull
Aug 7, 2006 09:28 AM
