Apes Install ?
Old Sep 17, 2013 | 11:02 AM
SBates08's Avatar
SBates08
Sweet!!! When I installed my 14" KST Mayhem bars I was out $416. Nuttin like doin it yourself. Hope all goes well for you.
Old Sep 17, 2013 | 11:37 AM
trainedkilla's Avatar
trainedkilla
Do the poly bushings....waaaaaay better than the rubber bushings.
Old Sep 17, 2013 | 02:50 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I'm assuming the LA Chopper Twin Peak bars except the same handgrips that go on the stock HD bars???
Or do I have to sing the MO Money song.....
Old Sep 17, 2013 | 05:15 PM
SBates08's Avatar
SBates08
Yessir they do. The last set I installed for a friend used the stock grips. Went back on without a hitch.
Old Sep 17, 2013 | 08:07 PM
Bagger_Vance's Avatar
Bagger_Vance
Originally Posted by HDV-GLIDE
For $14 delivered (e-bay), it's a no brainer since I'll have everything apart anyway. What's a little more vibration.......
These are the bushings you speak of correct?
http://www.ebay.com/itm/Polyurethane...55279b&vxp=mtr
Old Sep 17, 2013 | 08:22 PM
HDV-GLIDE's Avatar
HDV-GLIDE
They be the ones....
Old Sep 17, 2013 | 08:59 PM
Bagger_Vance
Just ordered a set ($14). I've got my 12" Yaffe classic apes ($88) on the way as well. Now I just have to figure out what +6 clutch and brake cables I'm going with. I'm thinking the Magnum Shielding Sterling Chromite II ($153 with shipping) but not for sure. Since everyone says you can go 12s without having to extend cables I don't have to worry about that so I'll have $245 in the whole setup, providing I don't break anything in the process. Can't beat that!
Old Sep 17, 2013 | 10:02 PM
simpkinst's Avatar
simpkinst
Tip: I went with the magnum cables and thought I could just replace the upper brake lines, but they connectors did not match up to the stock splitter. Save time and get the lower brake lines too.
Old Sep 17, 2013 | 10:34 PM
Bagger_Vance
Thanks for the tip. Maybe I'll go a different route then.
Old Sep 17, 2013 | 11:28 PM
Bagger_Vance
I did a little searching and Phat Performance has discounted prices on the Magnum cables. Everything I need (clutch, upper and lower brake lines) with free shipping is $213 and in stock. I read in a couple threads where the stock upper cable length used by Magnum is shorter by a few inches vs the actual HD cable so I'm probably going to go with +8 just to be safe.
EDIT: Oh, they also have 3% off orders over $200 so that brings it down to $206 vs $266 direct from Magnum.
SBRoadKing
Sep 10, 2016 08:09 AM
Spur56
Aug 25, 2016 02:14 AM
steelerdude1
2014-2024 Touring Models
Nov 11, 2015 06:37 PM
danman2540
Nov 27, 2010 10:27 AM
