How to keep heel shifter from falling off?
Old Sep 25, 2013 | 09:58 AM
bobby5's Avatar
bobby5
Default How to keep heel shifter from falling off?
How the hell do you keep the heel shifter from falling off ? Its fell off 3 times now i tighten the crap out of it and put locktite on it. Anybody have any suggestions besides taking it off?
Old Sep 25, 2013 | 10:02 AM
mkguitar's Avatar
mkguitar
at this point the teeth on the shifter and the shaft may be worn.
try swapping the front and rear shifters and tighten
otherwise alot of guys remove the heel shifter and they can be bought for cheap
Mike
Old Sep 25, 2013 | 10:05 AM
Keeper01's Avatar
Keeper01
Red locktite? You could also safety wire it.
http://en.wikipedia.org/wiki/Safety_wire
Old Sep 25, 2013 | 10:08 AM
AnotherBlackSG's Avatar
AnotherBlackSG
Do you use it? If not, then just remove it and get the little cap they have to cover the exposed shaft. If you do use it, I'd try replacing the set screw first. If that doesn't do it, then try switching it with the toe shifter. If that doesn't do it, then buy a replacement. BTW, make sure that the set screw is seating in the little grove in the shaft.
Old Sep 25, 2013 | 10:20 AM
beary's Avatar
beary
Is the problem the set screw keeps loosening or that the teeth are wearing?
Bery
Old Sep 25, 2013 | 10:30 AM
user 8373900's Avatar
user 8373900
Go get a new shaft, and possibly a new shifter. The splines are evidently worn.
Mark
Old Sep 25, 2013 | 10:36 AM
hamlinbikertrash's Avatar
hamlinbikertrash
Mark
My heel/toe shifter AND spline fell off the bike on a roadtrip. Never to be seen again. The lever arm on the back side still had the bolt in and was tight. So yeah, the splines wear.
Old Sep 25, 2013 | 10:41 AM
user 8373900
They do..Once the shifter is clamped all the way together, all you do by tightening is stretch the bolt.
Mark
Old Sep 25, 2013 | 10:53 AM
SBates08's Avatar
SBates08
I believe the OP is asking about the shifter peg and not the shaft. I lost my rear Willie G shifter peg (found every piece of it too) while riding one morning. Went to put it back on and realized I had installed it wrong to start with. I had it installed so that skulls faced each other not noticing that they only mount 1 way. Put it back on the way it was meant to be and haven't had any problems since. Hope this helps.
Old Sep 25, 2013 | 11:08 AM
one-up's Avatar
one-up
Get rid of it. It's a much cleaner look without the heel shifter and there's more room for my big foot. Just my opinion.
Attached Thumbnails How to keep heel shifter from falling off?-20130904_073910-800x600-.jpg
