Engine Whine
Old Oct 2, 2013 | 07:29 AM
rpbrown's Avatar
rpbrown
Default Engine Whine
I have an 04 Ultra with 70k on it. Last night as I was coming home, all of a sudden a loud whine started coming from the engine. Didn't matter what gear or if clutch was in or out, idle or running at 2k rpm.
Anyone have any suggestions on where to start looking for the cause?
Old Oct 4, 2013 | 01:54 PM
rpbrown's Avatar
rpbrown
A little more info now. I finally got a few minutes to look a little further.
The noise appears to be coming from the lower end, primary, on the right side. Sounds like a car that is low on power steering fluid.
Going to get into it this weekend but maybe someone has some ideas on where to start or what to look for.
Old Oct 4, 2013 | 01:56 PM
PA1195's Avatar
PA1195
Cam chain tensioners worn?
soft 02's Avatar
soft 02
Inner primary bearing if the noise is in the primary. Gotta go and have a look at it. or cam chain tensioners if on the right side.
Old Oct 4, 2013 | 07:04 PM
rleggs's Avatar
rleggs
I'd bet on it being the cam chain tensioners if they haven't been changed before now.
Old Oct 4, 2013 | 07:13 PM
omaho5's Avatar
omaho5
Opening up either or both is very straight forward. You said right and primary.
Sitting on the bike will place the primary on left.
rkoivisto
Jul 26, 2019 04:06 PM
Nuday
Apr 22, 2013 08:10 AM
67xlch
Exhaust System Topics
22
Sep 29, 2007 09:40 PM
pascowg
Jun 30, 2007 08:08 PM
friknjok
Jun 19, 2007 02:00 PM
