Andrews 57H Cams Installed - 2012 SG
Old Oct 3, 2013 | 12:03 PM
steelpony16's Avatar
steelpony16
Default Andrews 57H Cams Installed - 2012 SG
Afternoon all,
Just picked up my bike from Pocono Mt. HD. They Installed the Andrews 57H Cam and the Fulsac DX Headpipe.
All i can say is WOW. Final numbers are 94 HP & 103 Torq.
Comes on at 2200rpms and keeps pulling like a ****.
The one thing i don't like and i'm not sure if it is normal.
The valves are a little louder (Not a big deal)
There is a chatter noise coming from the air box.
Dealer said this is normal. Is It?
Going for a long FAST Ride
Old Oct 3, 2013 | 12:12 PM
0ldhippie's Avatar
0ldhippie
Yes, Normal. Glad you're happy!!!!
Old Oct 3, 2013 | 12:17 PM
SBates08's Avatar
SBates08
I'm interested in this same cam for mine. Did you change lifters, push rods, rockers or anything else? Any head work?
Old Oct 3, 2013 | 01:54 PM
fwb35's Avatar
fwb35
When I put my SE 204 cams in I put in new Comp Cams V Thunder lifters and adjustable push rods, much less noise then the stock set up now.
Old Oct 3, 2013 | 02:08 PM
Tailsfrommycrib's Avatar
Tailsfrommycrib
Dude that's awesome! I was thinking about the Andrew's 57h but decided to go with the tman 555 torque cams. I've heard nothing but good things about the the 57h. I'm glad they worked out for you.
Old Oct 3, 2013 | 02:29 PM
steelpony16
Whew damn glad to hear it's normal, Thanks Oldhippie.
SBates08, they had to change out the pushrods, they installed the Perfect Fit +.030
They said that they dont always have to change them out.
They are not adjustable, Pocono Mt HD Does not believe in the adjustable push rods.
I just went for another 50 mile ride, WOW am i glad i finally did this.
I never got it over 3500 RPM's (Yet), but it just wanted to keep pulling.
4 different times i looked down at the speedo and was like, HOLY ****, Slow down.
The motor never sounded like I had to shift. (Hope that makes sense)
Guess i will just turn the tunes up to drown out the chatter!
Old Oct 3, 2013 | 02:36 PM
SBates08's Avatar
SBates08
Sounds good to me. I'll probably change lifters and rockers when I do mine. Got a lot if rocker chatter now that MOCO says is "normal".
bigheadted
Oct 7, 2014 12:23 PM
Plaidfinger
Aug 4, 2012 07:50 AM
trapper_canada
Jul 14, 2010 07:31 PM
Big Jon 1
Exhaust System Topics
Mar 10, 2010 07:39 PM
04 rkcrr
Dec 10, 2009 05:48 PM
