Replace switch housing - switches?
Old Oct 9, 2013 | 07:10 PM
toe_hold's Avatar
toe_hold
Default Replace switch housing - switches?
I'm trying to replace the switch housings on my '99 Electra Glide, running into a problem with pulling the switches out of the existing housing on the throttle side. Haven't looked at the clutch side yet.
It appears to me the switch slide in slots directly out but the switch covers are in the way. A backing plate.
Note on the edges where the wires are you can sorta see the slots/guides.
Another view
From what I can see that turn signal switch is not coming out unless the switch cover is removed.
How does that happen?
T.
PS: yeah, already lost the brake wedgie thing. Stupid Harley tech.
Old Oct 9, 2013 | 07:24 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Just did this on my 04. Installed the extended turn signal switches. Loads of fun, that.
To remove the switches, you've got to remove the screws hiding down under that wiring. It holds that metal bracket down. Remove the screws.
Now lift the metal bracket at the back of the switch. It lifts in the switch housing about 1/8" and lets the switch come free. You will now be able to lift the switch up and backwards out of the housing. It's the same in both left and right housings, with a slight variation on the metal bracketry.
Old Oct 9, 2013 | 07:25 PM
dawg's Avatar
dawg
Gotta unscrew the plates holding them in.
Old Oct 9, 2013 | 07:27 PM
teamhess's Avatar
teamhess
I did the Clutch side on my 08 Streetglide to get to the volume dongle…. it is a bitch but it is what trapper said…. Lots of patience
Old Oct 10, 2013 | 02:35 AM
jrobinson424's Avatar
jrobinson424
And to save yourself a lot of misery, use a magnetic screwdriver. You'd almost need 3 hands if you don't.
Old Oct 10, 2013 | 08:17 AM
toe_hold's Avatar
toe_hold
I could have swore I did remove the screws, at least two of them. Maybe there's a third buried in there? Or perhaps I just didn't pull that bracket off. No one ever said I was the brightest bulb in the pack.
I'll take another look when I get home. Thanks all.
Oh yeah, magnetic screwdrivers are da bomb. Rip apart an old dead computer hard drive and save the magnets. Keep your tools attached to them and over time the tools will pick up that magnetism. Dang strong magnets.
T.
Old Oct 10, 2013 | 09:07 AM
fwb35's Avatar
fwb35
I have a 99 and did this last year, I believe there is another screw in there if I recall correctly
Old Oct 10, 2013 | 10:36 AM
user 8373900's Avatar
user 8373900
There is another screw in there, and the re-assembly is just as tedious if not more. Remember to wedge your brake lever open or you will break that stop light switch.
Mark
TOMMYBLAZIN
Oct 12, 2020 09:02 AM
Thumper26
Sep 13, 2016 08:42 AM
LKHA
2014-2024 Touring Models
Dec 29, 2014 09:25 PM
traveler
Oct 8, 2011 08:15 PM
Manish_Hawg
Jun 17, 2007 10:49 PM
