Replace SE Compensator - Dissater!
Old Oct 18, 2013 | 03:03 PM
jerseyjeff62's Avatar
jerseyjeff62
yea so what was it?????
Old Oct 18, 2013 | 03:13 PM
jackhis's Avatar
jackhis
It's just an embarrassing problem, I forgot to install the smallest spring disk. That caused the sproket moving left and right on the shaft, and the noise was created.
I will never work on the bike in the dark anymore.
Thanks again
Old Oct 18, 2013 | 04:17 PM
r0de_runr's Avatar
r0de_runr
glad it was something simple. I remember when I took out my key switch/lock and couldn't get it back in. Oh My Gawd I panicked. Folks on the boards said to just keep fiddling with it, it will go back, and it did.
Old Oct 18, 2013 | 04:45 PM
jackhis's Avatar
jackhis
I see what you've meant.
It's just my problem, I tend to rush and rushing causes error.
There is no more loud noise from the primary area, but I still don't have a chance to do a test drive. Hopefully next week.
Gotta go to work!
Old Oct 18, 2013 | 05:10 PM
dirtdobber's Avatar
dirtdobber
Glad you got it and it was a simple fix.
My compensator went out at 32,000 on my 07 Ultra.
First kick back through the ac then a knocking later on.
I really like the SE compensator, gave a few more amps on charging, no more kick back through the ac. Starts better.
Traded it at 60,000 and the se compensator was working just fine.
Some don't have a problem with the stock Compensator and some of us do or will.
Old Oct 19, 2013 | 12:18 AM
jackhis's Avatar
jackhis
I have been reading many threads about comp failure, so I decided to replace mine as my trip is almost 10k miles every year. Even tho, my bike's original stock comp is still running smoothly after 44k miles.
I guess I feel better this way. Time will tell.
Old Oct 19, 2013 | 12:02 PM
btsom's Avatar
btsom
Thanks again
Hate to throw any sand in your fix but I believe the big bolt going into the crank shaft is supposed to be a one time use. I don't know why, it could just be that they want you to have the fresh glob of lock tite on there or it could be that with the high torque value there is a stretch factor in the bolt and a second use will weaken it. I believe you should be good for a month or even a year but you might want to check with a better authority than me to see if you are OK long term with the current bolt. Any other members know for sure?
Old Oct 19, 2013 | 12:55 PM
jackhis's Avatar
jackhis
Nothing has mentioned the service manual.
I'll take it back. Yes, it mentions to put in a new bolt, but I think I'll be ok as I used the new one. Even tho, I took it back out, cleaned, applied new Loctite, and re-bolted again.
I don't worry about it for now.
Old Oct 19, 2013 | 01:53 PM
user 8373900's Avatar
user 8373900
Just remember..Extra parts= never good!
Mark
Old Oct 19, 2013 | 03:00 PM
Rickr01's Avatar
Rickr01
Originally Posted by hog95023
The lower half of the stock clutch basket
No Kidding, that looks bad! Did the clutch basket Just grenade apart while you were cruising along.....or did it have a little help?? lol.....That's scary looking.
