2014 cams
Old Oct 21, 2013 | 04:58 AM
jus2anoyu's Avatar
jus2anoyu
Keep in mind that unless the catalog specifies 'for off road or race use only' it's going to be an epa compliant cam. As someone else stated, many better choices out there.
Old Oct 21, 2013 | 05:18 AM
lp's Avatar
lp
Originally Posted by Hammz
EPA cams are those that have been approved & certified by the EPA as meeting the emissions certification process for the vehicle they are installed in for sale to the public. It's not a spec or part of the cam(s), but rather the entire part itself. It's all spelled out in Part 49, CFR.
I've heard that before but never read it. I figured it wasn't a specific part on the cam but how the cam performed emissions wise as part of the entire engine or something. Still I was wondering what attribute these EPA cams have that make them EPA compliant.
Originally Posted by bklynbob
Generally little or no overlap.
Thanks! Closest to an answer I've ever heard so far.
So overlapping. I wonder how that affects emissions. I also remember someone stating that Noise was part of it and high lift cams may cause more chatter or something so EPA cams might be lower lift for that reason. I dunno. Just trying to understand it all.
For the OP: I was thinking of trying to get a set of 2014 take offs. You know they will be cheap and probably perform better than 255s?
lp
Old Oct 21, 2013 | 05:45 AM
MNPGRider's Avatar
MNPGRider
Overlap affects emissions by allowing fresh intake fuel to possibly be drawn through the cylinder and into the still open exhaust valve port. The benefit of overlap is that the still open exhaust valve helps to draw in the fresh intake air.
I believe the 255 closed the intake valve at 25 degrees after BDC. If that is true, they will build more cylinder pressure than the stock cams shown in the diagram,which closes the intake at 30 degrees after BDC.
Old Oct 21, 2013 | 05:51 AM
BlackSpecial's Avatar
BlackSpecial
lp
I'll have some available in the spring.
Old Oct 21, 2013 | 06:41 AM
richie's Avatar
richie
They are CLOSE to SE255's but are not 255's. Different part number.
Does anyone know the what the new part no of the 2014 cams would be ? Thanks
Old Oct 21, 2013 | 08:31 AM
jmcdermit's Avatar
jmcdermit
Yeah ME TOO
Old Oct 21, 2013 | 08:57 AM
0ldhippie's Avatar
0ldhippie
I sure wouldn't waste my time switching cams for the new ones (or even 255s). There are so many good choices out there will actually make a real noticeable improvement in performance it's just not worth my time playing with stock cams..
Old Oct 21, 2013 | 09:08 AM
lp's Avatar
lp
Yeah I know but so many people report great results with 255s and out of the box performance of the 2014s that I'm willing to give these a try.
I have an 09 so it might worth the whole 100 bucks these cams will probably be selling at.
I have two sets of 255s with install kits on the shelf that I never put in.
lp
Old Oct 21, 2013 | 09:25 AM
Keithhu's Avatar
Keithhu
The increased cylinder pressure would explain some of the heat issues people often describe with the 255s.
Old Oct 21, 2013 | 10:47 AM
lp's Avatar
lp
I've heard cases of hard starting too. I don't have compression releases either...
lp
