WEIRD ELECTRICAL GREMLIN while riding
Old Oct 24, 2013 | 12:52 PM
satman's Avatar
satman
Default WEIRD ELECTRICAL GREMLIN while riding
While riding home alone at night last week (1600 mile trip) I looked down to tach and speedo and noticed both at zero with just about every warning light lit up in the guage faces. The odometer wouldn't increment as I rode along but cruise control worked fine. I was wondering if charging system was working but it seemed to be fine. I rode for about 20 mile till I was sure I was within 100 miles of home which is what AAA(RV coverage) will transport me for free if broke down. I pulled into a gas station and shut it off - waited about 10 seconds - started it back up and all was good!!! What happened? Making me rethink my upcoming 5000 mile trip to Az - don't like side of the road action at all! Got 25000 miles on my 2012 Road Glide Custom and dead reliable so far. Any ideas? Happen to you??
Old Oct 24, 2013 | 01:07 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Try cleaning of the VSS speed sensor as it is called. Metal shavings on it can cause this sort of issue.
Old Oct 24, 2013 | 01:17 PM
satman's Avatar
satman
Thanks for the reply - where is this sensor?
Old Oct 24, 2013 | 01:22 PM
Hogpro's Avatar
Hogpro
Former Sponsor
https://www.hdforums.com/forum/touri...-location.html
Redbeard719's Avatar
Redbeard719
It mounts into the top of the transmission, if I recall correctly. Should be able to see it easily as you look at the transmission from the right (brake) side of the bike.
Old Oct 24, 2013 | 01:32 PM
mkguitar's Avatar
mkguitar
VSS unlikely to affect tach.
if you have a piggyback tuner (or not) disconnect main fuse/breaker
disconnect ecm connections, run a tooth brush or if you have PLASTIC SAFE spray contact cleaner ( rag to catch overspray) on the contacts- and re-connect.
the computer could have got confused- like they do, the off/on sequence is usually what we do to reset a computer- this may have been a one-time.
charging system can easily be checked with a meter if you have reason to suspect that
other free checks are to pull and load test battery- check and clean battery cable connections at BOTH ends
https://www.hdforums.com/forum/touri...cable-pic.html
Mike
Old Oct 24, 2013 | 02:20 PM
satman's Avatar
satman
That makes more sense to me to - will do as advised. No one else ever have this problem?? Am I that lucky?
Old Oct 24, 2013 | 02:26 PM
satman's Avatar
satman
For what it is worth I have a thundermax with wideband O2 sensors and an Andrews 57 cam yada yada yada Will get after the connections tonite!
Old Oct 24, 2013 | 11:59 PM
ke5rbd's Avatar
ke5rbd
sounds like your ecm thundermax locked up on the gauge out puts. I would contact thundermax for advise.
Old Oct 25, 2013 | 12:09 AM
lowdowndad's Avatar
lowdowndad
1st Gear
My '07 EG Classic with Thundermax has done this twice. In 3 months. Pull over, shut off, re-start and wait 3 more months.
