build a 107" reasonable price?
Old Oct 30, 2013 | 12:22 PM
jlj6t's Avatar
jlj6t
Another supremely satisfied Fuel Moto customer here. Love my FM 107!
Old Oct 30, 2013 | 12:30 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by VETERAN75
Trying to build a 107 from my 96. I want to try and stay as reasonable on the price as I can...
While most don't want to needlessly spend money, there's a lot to be said for the quality of both parts and labor. And the differences can be significant. One shop might measure with a high quality micrometer and another with an old, worn out tape measure.
If you're really needing to go as inexpensive as you can, might want to check with a local high school or trade school and offer your bike as a project.
But before you spend a dime, make sure you know the specs on that crank. Hate to put any money into a build only to find out first time on the dyno that the crank won't hold.
Old Oct 30, 2013 | 02:08 PM
0ldhippie's Avatar
0ldhippie
I went cheap. Found a HD stage 2 103 kit on ebay for $600. Sold the A/C and 255 cams for $300. Ebay Andrews 54 cams for $235. Did have heads machined for ARCs for $250. ARCs, Cam bearings, breathers and SE tapered push rods were another $250 and Powercomamder around $350. Labor was $600. So around $2000 plus $300 dyno tune. 99hp/109tq. OK not so cheap??? Now thinking about headwork and putting power vision on... but that just brings up the crank problems?
Old Oct 30, 2013 | 03:55 PM
bklynbob's Avatar
bklynbob
Not much difference between a103/107, i prefer cast pistons to forged unless you ar going to beat on your engine. Get a set of HD cast 103 pistons and bore your jugs . Get your heads done and the am of your choice ......
Old Oct 30, 2013 | 06:53 PM
lkr0's Avatar
lkr0
I have a HQs 107 for 40k miles not one problem - there is a noticeable difference in a 103 vs. 107 - I have had both -
Old Oct 30, 2013 | 07:02 PM
lp's Avatar
lp
Fuelmoto has done the Homework on this... and the proper tune for it as well.
You can even install the kit yourself and save a few bones.
lp
Old Oct 30, 2013 | 07:39 PM
VETERAN75's Avatar
VETERAN75
Thanks for all the input. I am just looking into all options right now. First thing I will do is check the crank run out. Then go from there.
I put a HQ107 in a streetglide a few yrs ago. I'm sure if I part things around I can do it cheaper than what that cost was. But the wrnech will be thrown in if the runout is bad.
This is for a 2007 roadglide, and the 07's are the worse about bad cranks. I have read they beefed up the tightness for the 08 and later 96's
Old Oct 31, 2013 | 08:42 PM
Ben E's Avatar
Ben E
Unless you are ready to do the build yourself, I'd recommend FM as well. I ended up spending about $100 for each hp and lb of torque gained. $3,000 gained 30 hp/tq. 105/125. Drive to WI and back was awesome as well.
Old Nov 1, 2013 | 02:51 PM
VETERAN75's Avatar
VETERAN75
Yeah Ben I will be doing all wrenching myself. So I will save $ there but I'm looking to save money are parts and pieces. I'm still waiting for cold weather to set in here in South Carolina so it may be December before I take it apart.
I've talked with several builders to see what each one would do and have gotten a different build from each. Everyone has there own style and idea but they all pretty well have the same result. More power.
Old Nov 1, 2013 | 02:55 PM
OCBagger's Avatar
OCBagger
Fuel Moto!
