build a 107" reasonable price?
2K spent at a shop would have got me bored jugs (my cores), pistons, cams, lifters, pushrods, gaskets, installed and tuned. It wouldn't have included the SE throttle body, ported heads or clutch upgrades.
I wish somebody would come up with some cast flat top 107 pistons. I'd prefer to run them in a daily rider, but that's not an option, at least not yet. Boring stock jugs out to 98 or 107 is definitely pushing the cylinders to the limits. Getting a good running, long life motor is totally dependent on the skill of the person doing the machine work on the jugs. Fortunately, getting good cores isn't expensive, so you may not be able to rebore in case of a problem, but you can always pick up another set and do it again if you have to.
Now you guys have suggestions on the cams and throttle body size for a 110. I am contemplating having the heads worked but not sure on that yet. I got a 58mm tb with the kit but it's not for cruise. So it's for sale.
If you haven't looked at their website, do yourself a favor and check them out. Still happy with their work after 2 years and 10,000 miles.
FM research and rep I think I'm still better off going that way, than switch to the S&S power plant.
