All-in-All you're gonna' be layin' out around 3 large to get everything where it needs to be after it's all done and dialed in. There's some good advice in the above posts.
exactly about 3k will get you an excellent reliable set up
I know the heads cams and pistons should be matched sets. The clutch upgrade, pushrods, lifters, those things are what I am looking to find cheap if possible. eBay or whatever.
I'm actually looking at a couple 103 head and cyl new take offs at around 500 for the set and having those heads done, adding a good cam. I may be happy with that. The right stuff can put me 105-110 trq. Not worried much about the hp. Looking at pricing that route.
What do y'all think?
I hear ya... back in my day it was all about the HP now its all about the torque
Not only is torque so important for a bagger, but where the torque is made. 110 lb/ft of torque at 4500 rpm is useless on a bagger. Need it building strong at 3000 rpm.
