Screaming Eagle Ventilator?
Just purchased this one in May.
Screamin' Eagle Ventilator Performance Air Cleaner Kit-29490-09
http://www.harley-davidson.com/store...-18-2949009--1
The factory filter supplied with this setup is NOT an oiled K&N type filter.
It is the paper Harley filter and listed "Do Not Oil" in the installation instructions.
They do however have an K&N filter upgrade available for it.
Or just purchase the K&N element from any K&N dealer.
Edit:
I think the confusion is all because they seemed to have changed this.
The original Harley OEM filter for this was the "dry" type.
But now it looks like the only filter available is the K&N "oil" type.
So, it will depend on what type of filter element you have as to weather or not it requires oiling.
Very easy to tell them apart.
Either a dry paper looking filter, or the traditional K&N style gauze type.
The dry type does not get oiled.
The gauze type does.
And no difference in performance, IMHO.
However if you buy a replacement from Harley, they only offer the oiled one we make for them. There is also a chance that the dealer installed the K&N version on the bike when it got there from HD anyways.
Easiest way to tell, the original filter will say DO NOT OIL on the outer rubber edge and has white media new. Whereas the K&N is red new.
Screamin' Eagle High-Flo K&N Air Filter Element 29400022A | Harley-Davidson USA
according to the notes section in the screenshot below that I snapped, seems to require reoil:
So, it requires a lite coat of filter oil.
The paper OEM type filters do not require oil.
