Opinions on MAX HP A/C
Old Nov 11, 2013 | 06:23 AM
ejvette's Avatar
ejvette
Default Opinions on MAX HP A/C
I want to change the A/C on my new SGS and I narrowed it to the PM MAX HP A/C I like the contrast cut the best but not sure if it will look right on my color bike or if I should just go with the all chrome model what do you guys think would the contrast cut look ok on a bike with no black?
http://www.performancemachine.com/mo...rs/MAX-HP.aspx
Old Nov 11, 2013 | 03:37 PM
ejvette's Avatar
ejvette
someone must have have an opinion
Old Nov 11, 2013 | 03:41 PM
Bgill's Avatar
Bgill
Chrome and get their Servo cover too boot to clean up the details.
Old Nov 11, 2013 | 03:46 PM
mkguitar's Avatar
mkguitar
performance wise, just about all the aftermarket air cleaners have more flow potential than the motor can demand.
appearance wise, that is a choice- as above the servo motor plug and ugly wiring will be exposed, so you probably want to spend $70 for a cover for that.
+ the $450
consider that the Ness big sucker* is about $120 shipped
uses the stock cover.
and you have $400 left over
I know that to my eye ( and it is your bike)- when i look at other bikes I more appreciate the wise use of money, than thousands spent on bolt on parts- even worse is seeing the servo plug on the TBW bikes, 2nd best a some kind of a pie plate cover stapled on there that interupts the flow of the pushrod tubes...but that's my eye
mike
*the ness also has a chrome backing plate which complements the black and chrome motor- some others brands are cast grey, which looks like crap at the breather bolts ( make sure you order the chrome version if you want this)
easy install, the throttle body brace and the gas tank can remain in place ( tape over the bottom of the tank in case your wrench slips)
...and has an oiled, washable, reusable filter media
Old Nov 11, 2013 | 05:12 PM
nirschl's Avatar
nirschl
+ the $450
consider that the Ness big sucker is about $120 shipped
mike
That's some sound advice there. I too was looking hard at that PM A/C. It's a nice looking piece, but for a crazy price(worth it to some and not to others).
I instead landed a great deal on a new SE Ventilator. Looks great and probably performs as well as those more expensive and cheaper.
Cheers
Old Nov 12, 2013 | 01:06 PM
Bgill's Avatar
Bgill
If you shop hard you can find the PM and RSD air cleaners for right around $300 delivered. For some the quality and styling is worth the extra spend.
EBay and Eastern Performance are two places to I shop most often. EP is about due for one their doozy Holiday sales that are tough to beat....
Servo cover on sale now for $60.00 delivered:
http://www.easternperformance.com/ca...ne+air+cleaner
Old Nov 12, 2013 | 02:03 PM
grbrown's Avatar
grbrown
Wink
You can buy an SE stage 1 air filter kit #29400129 for 150 bucks, that will take your stock chrome cover. Nobody need know you have modified it!
Old Nov 12, 2013 | 02:07 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I think the chrome will look better with your bike.
Webo's Avatar
Webo
The SE Ventilator will flow more than your bike will ever need and it hides the plug as much as the stock cover if not a little more. And it will give you a little more leg room on the right side!
Old Nov 12, 2013 | 02:57 PM
jason12vb's Avatar
jason12vb
I'm a fan of the contrast cut and considering the Max HP as well. If you like the looks of it and don't mind the cost then go for it. It's your bike, get what you think will look best.
