Fullsac Installed
Old Mar 13, 2007 | 10:15 AM
ricaroo's Avatar
ricaroo
Default Fullsac Installed
I completed the install of the fullsac system, Looks good and sounds good, However I would like to replace the two heat shields on the right side and make it one.Has anyone done this, and if so where did you get the shield
Thanks
Rick
Old Mar 13, 2007 | 10:19 AM
FLHT's Avatar
FLHT
Default RE: Fullsac Installed
I have looked into this and can not find one that is long enough to do this in one piece. If you look at Drag or JP they have straight sections of heat shield
Old Mar 13, 2007 | 01:06 PM
tgaetto's Avatar
tgaetto
I think that if you can get ahold of a Softail Deluxe rear of front pipe,and match itup to the HD extended front header pipe (for FLH) and use the short piece to complete...
I was going to do this but ended up with other pipes.... Just measure the length and go to the stealer and look at different stock pipes you will find something. ask the service dept about take offs and save some $$.
Old Mar 13, 2007 | 03:24 PM
47Norton's Avatar
47Norton
I just added the Harley extended front heat shield. Covers the gap and looks much better. Plus my head pipe was pretty ugly in the gap. Got it on e-bay for real cheap. Never seen a one piece heat shield. Does someone make them?
Old Mar 13, 2007 | 06:12 PM
RonH's Avatar
RonH
ORIGINAL: ricaroo
Yes it does - any clearance trouble with the left side cover? I just was checking some stuff today and pulled the left cover only to find some blue dust on the left heat shield, and sure enough, a place on the left side cover that's worn way down from rubbing on the shield. Gonna have to loosen everything up and see if I can gain some more clearance....
Old Mar 15, 2007 | 06:46 PM
ricaroo's Avatar
ricaroo
Here is a couple of pics during the install
[IMG]local://upfiles/16240/935EC90CD9704532AD04883849F4DCE3.jpg[/IMG]
[IMG]local://upfiles/16240/8C063D0F9AEF4CA1B68593A9499BEDE6.jpg[/IMG]
[IMG]local://upfiles/16240/F59C51A3A28B415DBA8C27A883DD7907.jpg[/IMG]
zimm
Samson Exhaust
Nov 14, 2012 09:56 AM
Rickr01
Jul 23, 2012 11:13 AM
talon1674
Aug 6, 2009 10:56 PM
FLSTF
Exhaust System Topics
Mar 9, 2008 03:26 PM
RoadKing06
May 21, 2007 06:09 PM
