SE Nightstick reviews wanted
with a closed end cap, all the gasses are forced out between the disks through a passage that looks like a "W" in profile. the W has unequal lengths and it designed to break up sound waves while retaining flow.
The sound waves broken up and blocked are the higher frequency waves, so that the lower frequencies are emphasized.
(So a following rider or someone directly behind the bike will not suffer hearing a tinny rattle I sometimes notice from some exhaust systems)
in this way, Supertrapps have high flow numbers - and have been at or near the top of muffler comparos for over 30 years - while not being loud.
the epa rating makes them compliant as equipped for 2010+ models ( cat bikes).
They are also USFS complaint as spark arrest, in case you are racing your Harley through the forest
the "tamper proof" screws are easily removed, and like any disk system supertrapps the mufflers can be altered for sound or performance needs- ebay is a source for disks and screws, endcaps.
in minutes by the rider
the "open end caps" are equivalent to about 10 stacked disks ( flow)- more disks gives more flow and more horsepower, but torque may suffer ( this is always a compromise)
tuning on my previous bikes was a balancing act between pipes, carb and timing to enhance torque or hp.
on the 09 ( no cat) it is perhaps more apparent what the disks do.
and with the stock headers I find that closed end caps with about 9 disks left side, 15 disks rt side give good power, lots of torque for city riding and twisties.
My saddlebags carry a few more disks, when touring where the motor is at speed all day, I add about 3 disks each side to emphasis HP, good for passing.
alot of riders use more disks and/or open caps than I do- about 25 or 27 disks is equivalent to 100% flow without restrictive- however that can result in lower exhaust velocity and actually reduce potential performance due to scavenging at lower rpm.
My bike is not loud, I can come and go without bothering neighbors, but enough so that traffic knows I'm there. Hearing loss ( 35 years in rock and roll) is an issue for me.
here's my current set up...there are closed caps in there, and the left side has dummy disks sealed together with no flow between them so that the disk stacks are the same length:
I also sometimes use snuf r nots, which open/close with an allen key
On my various bikes, as the motors have been built or changed, the mufflers can be retuned to match.
and if compliance enforcement is ever an issue-there is a certification on the muffler - or if needed easily put back to stock with a few screws
mike
I will be putting them on a totally stock 103 with the cat still in the head pipe. I do not like loud, but want a deeper rumble than I am getting from my stock pipes. I'm hoping this does the trick.
I will review after install and let you know what I think.
I'm running the Fatshotz and Jackpot head pipe on my 110. I bought the tuning kit and went to 15 discs with closed caps. It's louder than stock obviously, but not appreciably louder than the stock CVO mufflers were with the Jackpot. They make substantially more power everywhere than the stock mufflers, and there was a huge gain in volumetric efficiency.
The Nightsticks depend on the closed end cap to kill the sound. That can make Supertrapps raspy in my experience.
