Deciding on Cam
Old Dec 1, 2013 | 06:21 PM
dbru899271's Avatar
dbru899271
Default Deciding on Cam
After doing a little research I decided to purchase the Wood cam. Now trying to decide which one to get. Debating on the TW777,TW888, TW6-6 or the TW-7H. I need your advise.
FLHT 96engine
09 FLHT
Old Dec 1, 2013 | 06:28 PM
senna's Avatar
senna
What other work, if any will you be doing to the motor?
Old Dec 1, 2013 | 06:29 PM
papifun's Avatar
papifun
go onto the Woods cam web site.... print out the dyno graphs with motor build u have.. print them out.. then look at RPM range where u like to ride most and this should help... do u like power spread out, do u want tq to ramp up quick ?
there are a lot of threads on Cams.. do a search... do u want top end speed or fast take offs ? do u want to lift ure front wheel from the ground ? do some homework... talk to the experts... Hillside and Fuelmoto are my choices... good luck.
Old Dec 1, 2013 | 06:30 PM
dbru899271's Avatar
dbru899271
I already have an exhaust, SE intake, power commander, SE compensator
09 FLHT
Old Dec 1, 2013 | 06:40 PM
equandt's Avatar
equandt
Drop the TW6-6 from your list and go with the TW-555. That will be the best for what you have and will allow you to step up to a 103 or 107 later.
Old Dec 1, 2013 | 07:23 PM
mewalker0's Avatar
mewalker0
I replaced my andrews 48 after reading all of the reviews here in this forum with the TW222. I am not saying some couldn't tell the differance, but from the seat of the psnts comparison, I can't tell a bit of differance. If I were you I would save the money and get the andrews...if you have a 96. 103 might be different. Just my opinion.
Old Dec 1, 2013 | 07:32 PM
Notgrownup's Avatar
Notgrownup
I have the Andrews 26H but i want the 48's now... Haven't considered Woods..Good cams, little pricier... Bob Woods knows his ****. Somebody with some of those cams will chime in soon...
Old Dec 1, 2013 | 07:44 PM
Uncle Chester's Avatar
Uncle Chester
The cams you listed for the most part like higher compression. I'd look real hard at the 222's if I were you. Either that or look into head work to help complement your cams. Last thing i would want in a bagger is a cam with a soft bottom end.
Old Dec 1, 2013 | 07:46 PM
'05Train's Avatar
'05Train
222 if you're dead-set on a Woods.
Old Dec 1, 2013 | 08:13 PM
5TIME's Avatar
5TIME
I have the 222s, and agree... More than this cam-wise would likely be wasted without other, significant mods in the head and compression area... Just sayin...
