Deciding on Cam
Old Dec 6, 2013 | 11:08 AM
  #31
equandt's Avatar
equandt
OP: What cam did you go with?
Old Dec 6, 2013 | 11:26 AM
  #32
UltraNutZ's Avatar
UltraNutZ
looks like he went with the 222 cam set.
Old Dec 10, 2013 | 11:23 AM
  #33
2lejit's Avatar
2lejit
subscribed.
Old Dec 12, 2013 | 12:37 AM
  #34
ke5rbd's Avatar
ke5rbd
the TW 222 is not a bad choice. It has excellent low end and good top end. Have done couple of maps for 96's with 222 and 555 and they both work about the same. The 222 come on about 200 quicker. One of the 555 had 30 tooth pulley and will run with the 555 cams and 10+ compression. The 777, 888, and 7H all have .575 lift which is a little much for the stock springs and the overlap little large for a stock compression 96. Lot of people run them with stock springs, but I feel should have the .585 springs or the SE BEEHIVE's
Old Dec 17, 2013 | 11:37 PM
  #35
equandt's Avatar
equandt
Originally Posted by hd_rolling
If your not planning on anything in the future the tw-222 are a good choice, if you might want to do 106/107 or head work in the future the tw-555 might be a better choice.
I ran the tw-555 in my 96" and it would pull very nice, later installed a 106 and had stage II headwork done and it really ripped. Now I'm almost happy.
+1 if you are planning to go bigger later the TW-555 is a great cam. I have it in my 107. The TW-555 will work fine in a 96" and be great in the 107".
The TW-222 is one of the best drop in cams out there. I have it in my 103. An am very happy with it as a "cam only".
Hope this helps.
FLTR2008TRIKE
Feb 2, 2013 06:08 PM
motoxer42
Oct 21, 2012 01:58 AM
Shirkey
Feb 27, 2012 09:33 PM
SoftailDon
Exhaust System Topics
Apr 8, 2010 08:25 AM
maineultraclassic
Dec 16, 2006 07:52 PM
