Trickle Charger
Old Dec 4, 2013 | 09:45 PM
Team Whidbey's Avatar
Team Whidbey
6th Gear
Default Trickle Charger
Can these plug into the adapter for heated gear? I have the heated gear pigtail, was wondering if the charger is a plug and play.
Old Dec 4, 2013 | 10:08 PM
3green0red's Avatar
3green0red
Yes, plug it in and you're good to go.
Depending on brand, look on the wall plug and check lights for indication of charging.
Give it a few hours to go into storage mode.
Old Dec 5, 2013 | 04:07 AM
mike5511's Avatar
mike5511
You don't want to use a "trickle charger". You want a batter tender. Yes, there is a difference. I've got three of the ones below and recommend them. Works on gel batteries as well.
http://www.autogeek.net/btplus.html
Old Dec 5, 2013 | 06:13 AM
RANGER73's Avatar
RANGER73
I would think the fuse for the heated gear is to large. The fuse for the battery tender is only a 5 amp fuse and is in the pigtail.
Old Dec 5, 2013 | 07:26 AM
Veekness's Avatar
Veekness
Not a problem to upgrade the fuse if necessary. Go up to maybe a 20 amp, of there's a dead short, it will still kick out.
Old Dec 5, 2013 | 08:58 AM
Scuba10jdl's Avatar
Scuba10jdl
You really don't want more than a 7.5A fuse in most battery tenders. Unless you're running a LOT of heated gear, you will be fine. My Gerbing gloves only use a 3A fuse.
Old Dec 5, 2013 | 09:49 AM
Dyno Don's Avatar
Dyno Don
I burned up a one year old battery by using a 2 amp "trickle" charger meant for automotive use. Apparently that much charge over an extended time period in the winter months will kill most motorcycle batteries.
I have since used Battery Tender brand chargers and have had no more issues.
As for the Gerbing plug...I have never seen a "motorcycle/atv" Battery Tender with that type of pin connector. Most tenders have a two prong plug. I have a Gerbing plug on the bike but chose to install the two prong tender plug onto the battery terminals for storage use.
Old Dec 5, 2013 | 10:50 AM
rhlhamlet's Avatar
rhlhamlet
Used a HD battery tender for a long time. Got 7 years out of my last battery using the tender only the last 2 years on it. Pigtail connection
Old Dec 5, 2013 | 11:57 AM
boro's Avatar
boro
Use battery tender. You can buy the single (rca?) pigtail from Gerbings.
Old Dec 10, 2013 | 11:25 AM
2lejit's Avatar
2lejit
Battery tender all the way.
