Baker DD7 install....
Old Jan 1, 2014 | 12:36 PM
  #51
qtrracer's Avatar
qtrracer
If you do a little search elsewhere there is a guy that has the DD7 , rob71458 and he has a stout 124 with the dd7.
Old Jan 1, 2014 | 12:50 PM
  #52
Sailrider 1's Avatar
Sailrider 1
Originally Posted by Stiggy
Just an interested subscriber here, but the 7 offers the "lo hole" 1st gear and ends up the same in 7th as the stocker does in 6th right? I just read the website and they talk about basically keeping the motor in the best of the powerband, the sweet spot if you will. As broad as the powerbands are on these things that sounds like fun but only if you want to shift it because you like to shift it. Having to grab another gear surely isn't going to make it faster going in a straight line! ( Point of reference here, Coming from a 5 speed I'll go to a 6 speed when and if my 5 speed ever breaks .) Good Luck in whatever you decide to do!
Pretty much exactly right stiggy. 7th is the same 1:1 as the six speed. So no I am not expecting my bike to magically be faster. I was alluding to the fact that my next step, a larger motor will be the faster, stronger part of the Better, Faster, Stronger....
I don't mind shifting, and looking forward to the lower first gear and closer ratios. Most of what I have read about the DD7 from other users is that they don't even use 7th gear unless cruising over 70 MPH.
Old Jan 1, 2014 | 12:51 PM
  #53
Sailrider 1
Thanks, I will check that out.
Old Jan 1, 2014 | 04:59 PM
  #54
bklynbob's Avatar
bklynbob
If you want an alternative to the DD 7 and more reliability, go with the Baker F6f kit and one of their 31 tooth pulleys.
Old Jan 1, 2014 | 05:26 PM
  #55
qtrracer's Avatar
qtrracer
He already has the F6F
Old Jan 1, 2014 | 05:31 PM
  #56
Sailrider 1
I already have the F6F kit. I've had it in for the last 30K miles. It's been great. Absolutely no complaints it functioned exactly as Baker advertised. I'm already committed to the Baker DD7 got the shipping confirmation yesterday. It should be here probably on Monday. I just listed my F6F in the classified section for anyone interested.
Old Jan 1, 2014 | 09:29 PM
  #57
bklynbob's Avatar
bklynbob
I also went with Baker's throwout bearing and Attitude adjuster.This will go on over the winter........
Old Jan 1, 2014 | 09:49 PM
  #58
Sailrider 1
Yep, those are coming too. I already have the Hayden M6. I installed it about 6 months before Baker came out with their attitude adjuster. I like the design of the Baker unit better, so I ordered it along with the Bully Primary cover.
Old Jan 1, 2014 | 10:43 PM
  #59
hdrider1's Avatar
hdrider1
Originally Posted by Sailrider 1
Thanks for the input and getting us back on topic. How do you like the DD7 ? Are you running the stock 96 ? What were the special tools you needed ? I do have the service manual. I'm weighing what I will need to pay for the special tools vs. having a local Indy mechanic do the install, though I would prefers to do it myself.
The DD7 is great. I installed it to get the lower gearing in 1 through 6. It's installed in a 107" Road King with Tman heads, cams, Boarzilla, and HPI tb. I use Redline Heavy Duty Shockproof in it and shifts smooth.
Sounds like you've got plenty of special tool recommendations. Installation isn't hard with the tools and manual. I figure what you save on the install pretty much pays for the tools, and then at least you know exactly how the work was done. It's hard to trust other peoples work on your bike.
Old Jan 2, 2014 | 07:35 AM
  #60
Sailrider 1
Thanks for the input. That's what I have been looking for. Good to know on the Redline. I have been running the shockproof heavy in my F6F. I was going to call Baker and make sure it was ok to use that in the DD7. I really like the shockproof and I have a case of it in my basement. Baker recommends Spectro 85W140 on their website.
I'm up to over $500.00 on the tools by my calculations. I have an Indy mechanic who is HD certified who will do the install for $450.00. He is a great wrench and a friend so I will probably have him do it, although I would like to do it myself just for the experience. I just can't see buying the tools to use once.
