Connector: Paint the plastic headset connector. Scuff it up first with some sandpaper. Put on a sealer undercoat, then paint over that. 'Bumper' black paint is a good match to the stock 'flat' finish.
Antennas: Fill in the 'low spots', first. They make a soft 'tape' used for sealing electrical connections outdoors. Put a piece of that in to build up the low spot(s). You can work it like putty. Wrap over your repairs and the remainder of the plastic antenna bases with some electrical tape. Then put a piece of shrink-tubing over the works, heat it up and conform it to the surface, sealing your repair.
Seat: Have the seat restitched at a local upholsterer.
If any of the repairs don't hold:
Replace the connector.
Replace the antennas.
Recover or replace the seat.
Alan
Take the covers off the comm plugs and heat them up with a heat gun. Don't just hold it in one spot you'll melt it. Make small circular motions with the heat gun. They'll look brand new when your done. May work on the plastic on the trunk as well.
