Pushrods through the top
Old Jan 10, 2014 | 10:47 AM
rasmukri's Avatar
rasmukri
I've pulled mine off a few times no special tools or anything, its simple.
But you will need special tools for the actual cam change part to lock the chain and if you change the berrings (you should since you are in there) you will need a special puller adapter thing-ama-jig
Old Jan 10, 2014 | 10:58 AM
Rock Chalk's Avatar
Rock Chalk
they were sure helpful when i did it.
Old Jan 10, 2014 | 11:07 AM
just plain john's Avatar
just plain john
My bike is an 05. MoCo has a cam change specific gasket set that has the breathers included. The throttle body will remain in place, and I'm awaiting delivery of the inner bearing remover/installer tool from Heartland.
Old Jan 10, 2014 | 11:14 AM
Redbeard719's Avatar
Redbeard719
I could be wrong, but if the Moco's cam change gasket kit is like the James Gasket kit sold by Fuel Moto ($50, btw), it includes gaskets for the old style breather assemblies.
I've never actually seen what is in the gasket kit from Moco though...
Old Jan 10, 2014 | 11:46 AM
UltraNutZ's Avatar
UltraNutZ
I'm assembling parts for a cam swap. I'm reusing the OEM pushrods. I see that the MoCo sells a rocker box wrench. For those that have done it, is it necessary to use it? Obviously the tank will be off, but having never had it off before I don't know what kind of clearances I'll have to work with. Also, someone mentioned a dogbone torque adapter. Again, is it necessary?
There are 2 rocker box wrenches;
upper rocker box wrench - $18 at jbtoolsales.com vs $35 from HD. Same tool
lower rocker box wrench - $18 at jbtoolsales.com vs $27 from HD. Same tool
you might want a cam lock tool (not really necessary as you can torque down the cam bolts with the rear brake pedal and a helper)
you'll need a bearing puller/seater to replace your stock inner bearings. Cheap insurance so do it while you have it opened up.
James Gasket Kit (JGI-17033-99) for your bike. Has all the gaskets and orings you'll need for cam swap, cam cover, rocker boxes, breathers, pushrod tubes, etc. You can get these pretty much anywhere. FM, Amazon, Fleabay, etc.
the first couple of times I did this I didn't use special tools but now that I do it regularly I have the necessary tools to make it easier.
Old Jan 10, 2014 | 07:08 PM
just plain john
This is a link to the kit, $90 at Surdyke. It has more stuff than I need, like bearings, but you can see the new breathers in the pic. http://houseofharley.com/en/products...FWUV7AodQlYA9A
Old Jan 10, 2014 | 07:09 PM
snip0721's Avatar
snip0721
you'll like the heartland kit. works great. had mine for several years now. done the rocker boxes both with and without the dogbone wrenches. much easier with, but do-able without....snip
Old Jan 10, 2014 | 07:23 PM
just plain john
So do I need dogbones in two sizes plus the ones UltraNutZ mentions above? I've never seen it done so don't know what to expect.
Old Jan 10, 2014 | 07:28 PM
12hdrk's Avatar
12hdrk
Motion pro torque wrench adapter. Read back through this thread. Part number given. Don't need dog bones if you get this tool.
Sent from my Galaxy Nexus
Old Jan 10, 2014 | 07:43 PM
snip0721's Avatar
snip0721
motion pro, or whoevers dogbone wrenches.....not worth $hit without a 3/8" drive, inchpound torque wrench.....snip
