Replace AC assembly or just filter?
Stage 1 A/C at the least from HD.. if you want to spend more $, then there are plenty of others.
Almost all aftermarket A/C will flow more air than even a Stage III 103 can eat...notable exception is the HyperCharger.
However, there is more to how much air an A/C will flow.
Internal Combustion engines run best on cool dry air.
Most aftermarket, (and all street legal), A/C's feed hot oily air into the air filter.
This compromises performance and also contributes to carbon deposits on the pistons (which can bring a whole other batch of problems down the road, especially with the 103's)
There are only a few companies making true performance Stage 1 intakes anymore.
DK Custom
NRHS
Hammer
I don't know of any others.
Here is a video of our Air Cleaners if that is a route that you decide to take.
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Like the screaming eagle the ness has an air horn to order the air to the airtake, this is better than a 90ş turn from flat backing plate to the intake
advantages over the screaming eagle:
easier install, the throttle brace and tank can stay in place ( mask the tank incase your wrench slips)
chrome backing plate complements the motor ( vs cast grey)
reusable washable oiled filter media
I see from your posts that you are trying to work through a stage 1.
once you open up the intake with a high flow air cleaner, and remove the cat ( as you mention in other post) you will certainly need tuning compensation- many of us use the nightrider.com Xieds/ Vieds to good result...and about $130
the budget minded- non complicated approach.
the ness and the screaming eagle both reuse the stock air cleaner cover- this conceals a very ugly plug and wiring on the TBW harley intake ( at about 8 o'clock as you look at it) which is a +
mike
Even the stock air box and filter will usually flow more air then what the body and intake throats can pull through.
Do what suits your fancy with respect to the air box and filter.
Our pals at hot bike did some great air cleaner comparos back then, and a carb with no air cleaner was only able to pull about 110 CFM without an air cleaner to order the air.
a cupped hand held at the carb throat came in at about 125 CFM...the Hype at about 155CFM and the S/E and Ness about 260 CFM.
Winner was the Zipper's velocity stack at just under 400.
the last 3 having more flow potential than the motor.
mike
