Louder pipes
Old Jan 17, 2014 | 10:09 AM
0ldhippie's Avatar
0ldhippie
First put a proper non-cat header on and see how ya like it. Then, if not enough, start listening to slip-ons.
Old Jan 17, 2014 | 10:16 AM
OldPhat's Avatar
OldPhat
+1 What Oldhippie said
Old Jan 17, 2014 | 10:19 AM
Xcrossbow's Avatar
Xcrossbow
Originally Posted by Cruisineasy1
Bought a '14 SG. The bike is great. Want it a louder when I yank on the throttle but mellow enough cruzin' along. Can this happen?? If I change out the exhaust, will it void the warranty??
YouTube is a great tool for sampling different exhaust sounds. Remember an exhaust on a bike started in a garage, or outside backed up to an automobile or a wall is going to give a deceiving sound. Best examples are in open driveways. Many will have examples of pulling out onto a highway and going thru the gears as well as driving by at speed.
Old Jan 17, 2014 | 11:33 AM
Tee Bagger's Avatar
Tee Bagger
[QUOTE=falconbrother;12208979]Look at true duals rather than mufflers if your really want the potato sound. I have tried several mufflers on my electraglide and, although I like the mufflers I have, it still has that sort of stock FL sound (which is fine with me).[/QUOTE
tru dat!!! I have 4"jackpots with comp baffles... then got v&h tru duals... totally different sound!
Old Jan 17, 2014 | 11:38 AM
Veekness's Avatar
Veekness
Actually, the 'potato' idle WAS a result of the dual fire ignition system, and not the exhaust. The waste spark was what created the off kilter idle, and that went away when the MoCo went to single fire ignition, wherein each spark plug fires independent of the other.
Case in point...take a shovelhead with a stock ignition, and you'll hear the 'potato' idle...install a single fire ignition, and that goes away. How do I know that? Cuz I did it!
My 2006 Street Glide doesn't have the classic potato idle. You can get closer to it with certain cams, but that's another story...
True story right there...
Old Jan 17, 2014 | 12:18 PM
Kugie's HOG's Avatar
Kugie's HOG
Listen to the SE Street Cannon mufflers. They have a great sound. This is what I put on my bike & I really like them. Does not void warranty. Don't even have to change air filter system or add download.
Old Jan 17, 2014 | 12:57 PM
Hausguy's Avatar
Hausguy
Been there, doing it and it makes a big difference.
Old Jan 17, 2014 | 02:03 PM
Webo's Avatar
Webo
Sounds like you are wanting the sound from a good set of slip on mufflers. A friend put on a set of VH Twin Slash mufflers with the stock head pipe and the bike was louder and had a deeper rumble than stock but not as loud as my Rineharts with VH Power Dual head pipe which is catless.
Old Jan 17, 2014 | 02:06 PM
BBSHK's Avatar
BBSHK
I have the CFR slip ons, added to the Fuel Moto 2/1/2 headers. Sound is awesome. Deep rumble.
Old Jan 17, 2014 | 02:38 PM
SoCalMike's Avatar
SoCalMike
Great . . .
Go ahead and "Pull the Trigger" on a set of pipes that give "A deep rumble but really bark when you open it up".
Giving ya 'chit . . . every Tom, Dick, and Harry that buys a new bike asks the same question that's been asked 125,981 times before. But, as you can see, people will still answer . . . . Shall we tell you what your next question is gonna be?
Have fun, ride safe . . . enjoy the ride and worry less about what people think.
