Baffle packing
Old Jan 19, 2014 | 08:09 AM
SavageChopper's Avatar
SavageChopper
Default Baffle packing
Any disadvantage to using muffler packing? I pulled the baffles out of my Bassani muffler because I noticed they rattled near in inlet. I plan on spreading the rear flange a little to fix the rattle, but was also thinking of using some muffler packing on the baffle while it was out to lower the sound a little.
Old Jan 19, 2014 | 08:12 AM
jus2anoyu's Avatar
jus2anoyu
I recently did my fatcat muffler. Made a noticeable change in the sound.
Old Jan 19, 2014 | 08:17 AM
Juice's Avatar
Juice
I used stove rope before, it worked better than fiberglass matt.
Old Jan 19, 2014 | 08:34 AM
northeimcustom's Avatar
northeimcustom
stove rope! never would have thought of that! probably lasts a while.
i've use steel wool before and had sucess with that.
Old Jan 19, 2014 | 08:47 AM
SavageChopper
Hmmm. May have to run to home depot. I assume you coil it on like putting a new grip on a baseball bat?
Old Jan 19, 2014 | 09:07 AM
Juice's Avatar
Juice
Yes, wrap it tight twist or leave a little gap between and this will adjust sound too.
Old Jan 19, 2014 | 09:16 AM
mwegryn's Avatar
mwegryn
The standard muffler packing will breakdown over time, there's a lot of heat in there. But as long as you can wrestle the baffles out it's pretty easily replaced.
Old Jan 19, 2014 | 10:26 AM
Deckman's Avatar
Deckman
I have used Moose Racing packing. Fuelmoto uses this packing in their Jackpot mufflers and it lasts longer than standard packing. There are different sizes etc. that should match your baffles. Definitely will change your exhaust note.
Old Jan 20, 2014 | 11:27 AM
RPS1981's Avatar
RPS1981
Thanks, Deckman. Just ordered some cheap online.
The packing is gone in my Jackpot mufflers and I've been wondering what to use. I know Fuel Moto has a packing warranty, but the hassle of pulling the mufflers and shipping... rather just do it myself.
patharley
Mar 29, 2014 09:56 AM
streetglidetroy
Mar 11, 2014 06:43 AM
harleyheaven
Feb 12, 2014 07:45 PM
pmcburne
May 30, 2010 07:38 AM
maineultraclassic
Aug 27, 2009 02:14 PM
