I don't think they get tighter but they do 'seize up' a bit over time (particularly the mounting bolts.)
True. The effort to undo a screw is not a reliable indicator of how tight it was when first installed. Damp and dirt get in and take a hold. Early Jap bikes had serious problems with that and it was common to have to drill out the stock cover screws, even on a near new bike. Modern bikes have much better quality metals and protective treatment, but the underlying problem is the same.
And this shows the value of a hand impact wrench for loosening.
My torque wrenches are longer than most other hand tools that I use. When I loosen a bolt that I had torqued previously it always seems too tight. I figure that I'm usually taking it loose with a shorter wrench and it doesn't have the leverage of the torque wrench.
I'm sure that's not always the case.
Edit: Inertia may have some effect on it.
