Batwing Bracket Again....
Old Mar 20, 2007 | 12:39 AM
jjsanta's Avatar
jjsanta
Default Batwing Bracket Again....
I was mounting up the Hogtunes amp this weekend when I noticed that the horizontal fairing bracketon the throttle side had snapped. I heard about this issue and I had noticed a little vibration on that side lately, so I wasn't completely surprised. Dealer was great though - I just brought the snapped bracket in and they handed me a new one under warranty. Point is, this is a really common problem so keep an eye on these things.
Old Mar 20, 2007 | 05:08 AM
SeaHag's Avatar
SeaHag
Default RE: Batwing Bracket Again....
If you're in there dicking with them anyway, just put a little reinforcement weld on the tabs where they just bend them over and you won't have to keep replacing them. They are cheap junk brackets and will continue to fail after the warrantee expires unless you do something to help them out.
Old Mar 20, 2007 | 09:15 AM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: SeaHag
I was going to have a local sheet metal house bend up some .06 thick angle and weld them piggybacked to the factory bracket as well.
Old Mar 20, 2007 | 09:28 AM
johnnyspeed's Avatar
johnnyspeed
It is funny you mention the bracket failure, I was also installing my hog tunes speakers and amp on sunday and found the same thing, man the new system kicks a@@ the only problem now is that i cant here myfat catsoi geuss im going to have to get louder exhaust, i see aevil circle starting [sm=happy046.gif]
Old Mar 20, 2007 | 09:37 AM
kurtlange's Avatar
kurtlange
look into these--
http://cgi.ebay.com/ebaymotors/Harley-Electra-Glide-fairing-brackets-stainless-steel_W0QQcmdZViewItemQQcategoryZ35560QQihZ003QQit emZ130082607652QQrdZ1
here's the other forum link-- http://forums.delphiforums.com/elect...es?msg=16912.1
i'm not affiliated w/ these guys...
Old Mar 20, 2007 | 10:35 AM
jbhawley's Avatar
jbhawley
wish i had known about these before i put my new set on.
Old Mar 20, 2007 | 12:23 PM
SeaHag's Avatar
SeaHag
Here's a pic of the seam I welded up to give the area more support...[even though my stock ones never have broken in my first 5 years].
Old Mar 20, 2007 | 01:33 PM
jjsanta's Avatar
jjsanta
Those things look great! Too bad the auction is over, and they don't seem to be selling anymore at this time....
Old Mar 20, 2007 | 10:30 PM
2005UltraNC's Avatar
2005UltraNC
Mine broke on the other end - another MoCo POS
Old Apr 10, 2007 | 09:49 PM
swalter10's Avatar
swalter10
This is for jjsanta, my mistake.
While you are in there, check the vertical brackets on each side of the radio. Look at the top where it is attached to the inner fairing. That is where the break will be. That is where my left bracket broke. I replaced the speaker bracket, and had the broken vertical bracket welded back together at the shop. I painted and reinstalled the repaired bracket, then removed the right side bracket and had it welded at the seam for strength.
SW
