Installed the biketronics kit
Old Mar 5, 2014 | 12:58 PM
sbeast's Avatar
sbeast
Default Installed the biketronics kit
installed the biketronics 6.5" system with the bt454 amp. stuffed a bunch of polyfill around each speaker as well. it sounds awesome in the garage and on the first 2 rides.
then last night when i went to ride home from work, it was about 38 degrees outside, and the amp refused to turn on for the first 5 miles of the trip, then randomly came on by itself while sitting at idle at a light. it shut off again for a few seconds a little further down the road, then came back on. i've checked and rechecked all the connections under the fairing and everything seemed tight. i rechecked all the connections and crimps and put it back together, and i'll try it out tomorrow when the weather is clear again.
Old Mar 5, 2014 | 01:08 PM
Keithhu's Avatar
Keithhu
What head unit? I had problems like that but it was the head unit - Sony DSX-MS60, the third one was the charm.
Old Mar 5, 2014 | 01:18 PM
dirtdobber's Avatar
dirtdobber
If it is a factory head unit check for a bad ground. If you connected under the fairing on the frame and you did not clean the paint that could be your problem.
Old Mar 5, 2014 | 01:27 PM
sbeast's Avatar
sbeast
i did not think to clear the paint on the frame before i installed the ground, thats a good idea, i'll have to hit that with sandpaper or a dremel tomorrow
also, still using the stock HK radio (which i realize is probobly why the sound isn't as clear as it could be)
Old Mar 5, 2014 | 02:23 PM
Beav's Avatar
Beav
Cleared my problem...
Old Mar 6, 2014 | 07:27 PM
sbeast's Avatar
sbeast
i scraped the paint off from around the threaded hole i connected the amp ground wire too, added a bunch of polyfill padding around the speakers while i was in there too. gonna test it out tomorrow.
Old Mar 6, 2014 | 07:33 PM
dirtdobber's Avatar
dirtdobber
use some of the battery sealer, spray type, usually purple or red. This will seal seal the bare metal and keep it from rusting.
grampaG
Audio Systems
Jun 14, 2019 06:58 AM
rg567
Sep 19, 2014 11:35 AM
ICIBUY
Jun 29, 2012 06:07 AM
brandss
Mar 19, 2012 07:37 PM
04Glider2
Jan 6, 2012 12:29 AM
