Head work/big bore please post
Old Mar 8, 2014 | 05:39 PM
kishstl's Avatar
kishstl
Originally Posted by BrianSF-GA
OP ... know that your 2011 103" already has ACR's and the TW-777's "like" higher compression ratios. Before you make any decisions, call Bobby Wood and ask his opinion since you are running his cams .... it will be a phone call well made. I went through the details of the FM107" kit with him and his only added recommendation was the 30T sprocket mod since I ride two-up in the mountains the majority of the time .... he was right on the money.
I'm very much leaning toward FM or Hillside. Doesn't seem like you can go wrong with either. Did you start with a 103 and ACR's and if so did you send your heads in or get exchange heads? How did they handle your ACR's?
Old Mar 8, 2014 | 06:51 PM
rockajet1's Avatar
rockajet1
You might want to give Frank Drago a call at Drago's Bike Works. He will talk to you for as long as you want about your build. Great guy who really knows his stuff.
Old Mar 8, 2014 | 07:04 PM
BrianSF-GA's Avatar
BrianSF-GA
I started with a 103" with 1,500 miles that had a Stage 2 kit (SEPST, 254E's & SE clutch spring), Stage 1 AC, V&H PD's & 4" Bassani Megaphones w/2-1/4" baffles ... the base dyno run with the SE Heavy Breather replacing the Stage 1 AC put down 87rwhp/103rwt.
Since the heads were mint with 1,500 miles and only 9 months old, I had the builder send them to FM for their Level B work instead of FM providing off the shelf heads. It took quite a while, but it was worth the wait to have my actual heads back. Honestly, I am not sure if the builder removed the ACR's or if FM removed them for the head work. A quick call to Jamie at FM could answer that question.
I took the original 103" pistons/rings, SE 254E cams, stock cams, SE adjustable pushrods, Stage 1 AC and other parts and auctioned them on Ebay to recoup some of the build cost.
Nickd2689
Dec 25, 2016 11:34 PM
Steel Wheels
General Topics/Tech Tips
Dec 3, 2015 03:28 PM
Improved700
Aug 6, 2014 07:01 AM
mike06train
Sep 7, 2011 03:18 PM
jshull
Exhaust System Topics
11
Dec 27, 2010 10:58 AM
