Check Engine light
Old Mar 9, 2014 | 09:10 PM
HOGILAC's Avatar
HOGILAC
Default Check Engine light
I reset my MAP and went out for a ride..., my check engine light came on after about 25-30 miles. I stopped and when I restrarted headed back home.... it didnt come back on. Rode about 40 miles today and didnt come back on. Could it have been the PC making adjustments. Gas mileage still sucks.
Old Mar 9, 2014 | 09:21 PM
skratch's Avatar
skratch
if your check engine light came on, then the ecm is detecting some kind of fault. if the light went out, the fault 'self corrected' but the code will still be in the memory. you really need to pull the codes and find out what specific fault it was, it will come back.
Old Mar 9, 2014 | 09:25 PM
HOGILAC's Avatar
HOGILAC
Default PSI on EG
Still getting use to my EG...., Where is a good starting point for PSI in my shocks..., I ride 2 up 30% of the time.
Old Mar 10, 2014 | 12:44 PM
skratch's Avatar
skratch
look in the manual and start with the psi that they recommend. then adjust as necessary.
not being a smart ***, but i never ride 2 up, and i don't have air suspension.....
Kyle C Kirk
Nov 9, 2015 02:13 PM
Indpthwill
Nov 1, 2014 10:55 AM
chizman
May 15, 2011 04:35 PM
txfxstrider
Aug 31, 2009 10:24 PM
jrspringer06
Oct 26, 2008 06:08 PM
