Lowering Brackets, Good Idea or Not?
Old Mar 14, 2014 | 07:20 AM
rcreechssr's Avatar
rcreechssr
Question Lowering Brackets, Good Idea or Not?
Can't find anything in search, except for one comment said lowering brackets can crack swing arm.
Problem: I have a 2013 Ultra Limited that is just about 1" too tall. Can't see spending several hundred dollars for lowering shocks (has air adjustable stocks now) or even a new seat (love the stock seat). Saw some lowering brackets on eBay priced $20-$40.
Can anyone talk intelligently about whether or not this is an acceptable alternative? If it's not a good idea I'll probably just live with the stock height as opposed to spending a pile of cash for a 1" ride drop.
Old Mar 14, 2014 | 07:28 AM
Jumpman's Avatar
Jumpman
Lowering blocks are fine.
* stop looking at the cheap ones tho. Burly, LA Choppers, Etc. make MUCH better units...and they can be had for between $100-$150.
Old Mar 14, 2014 | 07:39 AM
sfd421's Avatar
sfd421
2nd Gear
I bought mine off Fleabay. They cost me about $50 and I've had them on the bike for a few years now. No problems at all. It makes a difference when you can sit flatfooted when stopped at a light. The shocks are the proper way to go but the lowering brackets work fine.
Old Mar 14, 2014 | 07:56 AM
northeimcustom's Avatar
northeimcustom
your going to get many opinions on the use of lowering bracket. i have mine 2 inches lower than stock on my '13 street glide with 1000+ miles of trouble free results with the brackets. rides a little 'harsher'
most 100$ ones are the exact same as the 30$ ones on the ebay. do your homework before you buy! i dont see you having any issue with the 1'' drop.
Old Mar 14, 2014 | 08:03 AM
barrygreen's Avatar
barrygreen
I have had several different brands, I recommend looking at the ones below. Probably the heaviest an well built....don't be fooled bu the price.
http://www.ebay.com/itm/161107568724
Old Mar 14, 2014 | 08:20 AM
Jumpman's Avatar
Jumpman
Or...
This.
Progressive Suspension (Burly) Lowering Block Kit - Harley-Davidson Electra Glide 2009-2013 / Road Glide/Road King 2009-2013 - Black - B28-42008
http://amzn.com/B0067ERT7K
Old Mar 14, 2014 | 08:22 AM
SafetyMan's Avatar
SafetyMan
I used the Burley blocks, nice and stout.
The brackets not so much.
Old Mar 14, 2014 | 08:29 AM
Hecklerboy's Avatar
Hecklerboy
Have you thought about a used set of Street Glide shocks?
They should lower you down about an inch just like a SG.
You should be able to pick up a set on Ebay for around $150.
squaredaway's Avatar
squaredaway
as long as its a 2009 or newer.. Your wires for taillights is on the side of fender not inside.. You will rub the wires. Or move the wires to the outside of fender.. Rides a little rougher. but worth it to have your feet flat at a light.
Old Mar 14, 2014 | 08:31 AM
Proaction14's Avatar
Proaction14
I use the Progressive Suspension blocks, 2 years on them with no issues. I dropped the back 1".
