Wiring question again
Old Mar 23, 2007 | 05:16 PM
dansflhti's Avatar
dansflhti
Default Wiring question again
The orange/white wire inside the fairing not attached to anything.....with a red cap on it....does any one know what the fuse rating on it is?
I'm thinking of using it as the power source forthe spotlights on my on my 06 e-glide standard.
I'm rewiring them with a relay so they will be on with hi-beams as well as low beams.
Thanks for your help.
Old Mar 23, 2007 | 06:41 PM
RoadKingon's Avatar
RoadKingon
Default RE: Wiring question again
put a 12V lightbulb on it and start pulling fuses on the side panel until you find it. Look at the fuse for the amp rating.
Old Mar 23, 2007 | 09:43 PM
choochoo's Avatar
choochoo
just an extra power wire when ignition is on. Service manual says it is for HDI.
But you could use it. It goes back I think (need to get book out) to main power fuse.
Most people just splice the same wire on the accessory switch to the spot swtich.
That way you do have two fuses in the system, one for main power and one for the accessory switch (hope this is correct, don't have manual in front of me).
enjoy!
Old Mar 23, 2007 | 10:14 PM
dansflhti's Avatar
dansflhti
Thanks choo choo....i guess its time that i get a shopmanual.
Old Mar 23, 2007 | 10:40 PM
SteelCityScooter's Avatar
SteelCityScooter
You could just do the passing light MOD wiring instead.
Alot easier than adding all the other stuff.
Old Mar 29, 2007 | 01:10 PM
questor's Avatar
questor
<You could just do the passing light MOD wiring instead.
To perform this mod, where is the wiring located?
DavesEagle
Electrical/Lighting/Alarm
Dec 16, 2018 10:29 AM
knitski
Audio Systems
May 24, 2017 12:21 AM
speakerfritz
May 23, 2011 08:07 PM
ronyd
26
Dec 22, 2007 05:22 PM
Bldr1000
Oct 27, 2007 02:15 PM
