left saddle bag wont fit ?
Old Mar 19, 2014 | 11:35 AM
Timothy Rau's Avatar
Timothy Rau
Default left saddle bag wont fit ?
Took bike apart to be painted and can't get left bag to line up correctly? I have tried every combination with brackets loose to get holes to line up and the bag is slightly above holes with brackets all the way up. What am I missing here ? I have had the brackets off many times before and never had a problem. I did install new rear fender and a eliminated the grab bar with brackets at same time. 2005 ultra . Any suggestions would be appreciated.
Old Mar 19, 2014 | 11:44 AM
Noble Jim's Avatar
Noble Jim
Check the rubber cushions in the bottom of the bags. If they are good, keep everything loose. When all is aligned and fasteners are in place, tighten the brackets. Hope this helps.
Old Mar 19, 2014 | 11:48 AM
jeffreydsilver's Avatar
jeffreydsilver
Betcha it's missing!
Old Mar 19, 2014 | 12:09 PM
Def Mute's Avatar
Def Mute
If they were missing, wouldn't the bag hole be below the bracket hole? OP said bag hole was above bracket hole? Could be the rubber tab holding the rubber cushions in bad position. Had one do that on my '99 RK. Might also check the alignment of the bottom rail, that the bag mounts on top of. Give it a swift kick, it'll line up!
You said you removed the fender/grab rail, try loosening the fender support bracket.
Old Mar 19, 2014 | 12:17 PM
st john's Avatar
st john
Just take your time and reverse engineer everything you did. I wish i could be more help but everything I do I do right the first time so I have no experience from any mistakes. I am sure you will work it out.
Old Mar 19, 2014 | 03:04 PM
RaceFace's Avatar
RaceFace
Bro.....beer ALWAYS helps these situations! It will round that edge and you will realize that you may have been over thinking it.....then again, the more beers you have, you may just realize that you don't need a left bag at all!!!!
Hang in there and good luck!!
Old Mar 19, 2014 | 11:10 PM
Wv7o's Avatar
Wv7o
For what it's worth, I will drink beer until this project is complete.
I know, I'm not much help.
Old Mar 20, 2014 | 12:22 AM
monster715's Avatar
monster715
If you just had the bag painted it's possible you didn't get the rubber cushions on the bottom all the way in. If I remember right you gotta help pull the nipple from the inside of the bag while you push from the bottom. If it's not in all the way the bag probably won't line up
Old Mar 20, 2014 | 10:49 AM
Timothy Rau
Thanks for responses. I will try the beer technique this weekend.
Old Mar 20, 2014 | 10:51 AM
Uncle Larry's Avatar
Uncle Larry
and do it in the morning ... Remember ... BEER, The Breakfast of Champions ... and Saddlebag installers too!
