EITMS and Fuel Moto PV map
Old Mar 20, 2014 | 12:22 PM
WDE's Avatar
WDE
Default EITMS and Fuel Moto PV map
I was comparing the FM map with stock map. I noticed the EITMS disabled and the activation temp for EITMS to kick on was changed to 310 *C.
Is this just an oversight, possibly meant to set at 310 *F? Why would it otherwise be set so high?
What would be the advantage to have the system disabled at the ECM?
I changed the setting back to stock configuration with EITMS on, and activation at 140 *C.
Old Mar 20, 2014 | 01:50 PM
ke5rbd's Avatar
ke5rbd
Got to your Setup/options at the top of the Win/PV and change Units from Metric to Imperial. That should change the C to F. Then mine on FLHTK is set at 285°/141c for on and 275°/135c off. You could convert it to C if needed. You can activate it by changing to 1 in the limit and switches menu. You can also activate it by twisting throttle backward for a few seconds and the cruise light will flash orange or yellow when off and green when it turns on. I haven't had mine come on in couple of years and I guess they don't pay too much attention to it. Get the map right and don't get hung up in traffic and it won't come on.
Old Mar 20, 2014 | 02:35 PM
Joe12RK's Avatar
Joe12RK
I'd send Jamie at FM an email - he's usuallly quick to respond.
Old Mar 20, 2014 | 03:13 PM
EasTexUltra12's Avatar
EasTexUltra12
I just asked Fuel Moto about this same thing yesterday. There is no real reason FM turns the EITMS system off. Jamie said you can just turn it on again if you want to. I did.
David
Old Mar 20, 2014 | 04:57 PM
12hdrk's Avatar
12hdrk
The EITMS, IMO, is pure marketing crap. Does absolutely nothing except scare the crap out of you when it kicks in. FCS fans from wardspartswerks and disable eitms.
Sent from my Galaxy Nexus
jhblaze1
Vance & Hines
16
Jul 1, 2018 12:40 PM
JokerWhiskey
2014-2024 Touring Models
Jun 8, 2016 06:08 AM
chief1600
May 14, 2013 03:07 PM
PIGGI
Mar 1, 2013 08:37 AM
fuct44
Aug 5, 2007 06:38 AM
