Road King Classic Fuel Crossover Upgrade
Old Mar 21, 2014 | 07:52 PM
abingham's Avatar
abingham
Default Road King Classic Fuel Crossover Upgrade
Just removed my tank for the first time and it was a bit of a task. I want to replace the crossover with a disconnect. Looking at the Goodridge with quick disconnect. It says its a 1/4 inch hose. My stock hose is 5/16. Will the 1/4 inch work??
Sorry if this is the wrong forum. 1st post
Thanks
Old Mar 23, 2014 | 11:49 AM
abingham's Avatar
abingham
Wow no one has used the goodridge crossover.
Old Mar 23, 2014 | 12:44 PM
mkguitar's Avatar
mkguitar
if you plan on removing the tank often, I suppose.
I remove tanks this way:
1 short piece of fuel line 5/16" - with a bolt in one end as a plug
1 5/16" bolt...about 1" long
remove crossover hose clamp on rt side of tank
pull the hose off the nipple and put finger over the ends of hose and nipple
put bolt in hose to plug it
put short piece of hose with bolt in it over the nipple.
you can use clamps if going to be awhile.
mike
Old Mar 23, 2014 | 01:38 PM
FinalShot's Avatar
FinalShot
I don't think so. 1/4" is quite a bit smaller than 5/16" and I don't know if you would be able to get that on. Plus, I would think you would be over stretching the hose and that could lead to a gas leak if the hose cracks or tears. Why not find one that is 5/16"?
Old Mar 23, 2014 | 02:29 PM
just plain john's Avatar
just plain john
Harley offers a crossover replacement hose, braided stainless with compression fitting for about $35 if I recall correctly. You can reorder the rubber pieces if needed. I installed one after removing the tank. Easy off and on now. Found this on fleabay, this is the correct size and looks like the Harley piece. http://www.ebay.com/itm/Stainless-Br...-/281180603726
Old Mar 23, 2014 | 02:47 PM
Jumpman's Avatar
Jumpman
That Goodridge piece looks slick.
Double the price of the Harley crossover line seem reasonable considering it has the fuel cutoff. I'd do it.
Shame it doesn't have the compression style tank connects like the H-D line does.
Old Mar 23, 2014 | 04:24 PM
mrmud4x4's Avatar
mrmud4x4
Can get one of these....in 1/4 or 5/16...made by Motion Pro
motorcycle superstore
http://www.motorcycle-superstore.com...t-off-coupling
Old Mar 23, 2014 | 04:52 PM
shakrr's Avatar
shakrr
I just did the same thing when I changed the filter you need the 5/16 quick connect they have it I bought one just search for 5/16 goodridge
Old Mar 23, 2014 | 05:42 PM
99Roady's Avatar
99Roady
I did this a couple years ago. Purchased one of each below and it works like a champ.
http://quickcouplings.net/osc/produc...d4fe9b6aae6d55
Old Mar 24, 2014 | 11:07 AM
abingham's Avatar
abingham
Thanks Everyone. I thought the 1/4 would be too small...just wasn't seeing any of the goodridge in 5/16. Just got done ordering a chunk of braided hose and compression fittings from Spectre and a quick disconnect to add to the middle... a little cheaper than the goodridge with a little elbow grease thrown in.
Bryce05
EVO
Jan 15, 2018 05:04 PM
Tarkus60
Dec 8, 2016 07:18 AM
Goupner
Jan 19, 2015 07:04 PM
pktrusty
Feb 24, 2013 11:12 PM
anubisss
Oct 12, 2006 12:17 PM
