I did a search for this; but, could not find anything on the forums. (I have also read and re-read both manuals cover to cover looking for answers to my questions.) I have upgraded the software to 1.17.4.
I have looked through every Settings sub-menu. Maybe, I'm just overlooking something obvious; but, I have been unable to answer these two questions.
1. How do I set the default country to USA? Every time that I want to enter and address, the first thing that I have to set is the country (I have to change it from Canada - the default) to USA. I would like to change this default to USA since I don't travel in Canada (at least not very often).
2. I have moved since purchasing the motorcycle. How do I navigate the menus to change my home address so the motorcycle stops trying to take me to my old house every time I forget to enter the address manually and select "Home" from where to?
I went to the dealer and had them change the default. Apparently there is some top secret download that they can install that will change the default country. The only problem is that this change only lasted about a month then the default country reverted back to Canada. Maybe this will be fixed in the next firware upgrade.
