hot or cold fluid change
Old Mar 25, 2007 | 09:33 AM
ricaroo's Avatar
ricaroo
Default hot or cold fluid change
I can't ride today ,it snowed last night but anyway I want to change the transmission fluid I usually do it with the fluid warmed up. Anyone change the fluid cold?
Old Mar 25, 2007 | 09:36 AM
bay13's Avatar
bay13
Default RE: hot or cold fluid change
I change all fluids when they are hot, however if I was going to do it with cold fluid, I'd just allow for a longer drain time.
Old Mar 25, 2007 | 09:42 AM
dawg's Avatar
dawg
Not the tranny, but I recently did the oil cold (really cold) after my rebuild. I just pulled the plug and let it sit for quite awhile.
Old Mar 25, 2007 | 10:13 AM
electaRICK's Avatar
electaRICK
let me ask you this,,,, do you like spreading room temp. butter on your dinner roll,, or do you enjoy refrigerated butter????
Old Mar 25, 2007 | 11:19 AM
ricaroo's Avatar
ricaroo
I use refrigerated butter that stays soft, sooooooo now what? The bike is in a heated garage 65 degrees
ORIGINAL: electaRICK
Old Mar 25, 2007 | 11:41 AM
electaRICK's Avatar
electaRICK
do you always answer a question with a question?????
maybe you answered it your self,,,, sounds like you prefer synthetics
i'm only trying to help! lol
hey.. 65 degree garage,,, got room for 2 more bikes next winter???
Old Mar 25, 2007 | 11:46 AM
choochoo's Avatar
choochoo
bike is in a heated garage? *****!!!!!!!!!!!! lol
seriously.
Just change the oil as normal.
Let drip for ten minutes after flow stops.
Put plug in, refill then go ride. ohhhhhhh wait it's snowing, read the first line!!! again lol!!
Old Mar 25, 2007 | 11:49 AM
easyglider's Avatar
easyglider
Bike should be at normal operating temp.
Old Mar 25, 2007 | 11:53 AM
StreetGlide2006's Avatar
StreetGlide2006
I recently changed my trans. to Red Line Shockproof. Garage was warm. Outside was snow. I just let it drain a lot longer and then poured about a 1/2 qt of SYN 3 I had leftover through it also to help chase out anything that might be laying around. Then let that drain a long time too. Then put the Red Line in until it started to run out the drain and put the plug in and filled it to the proper level. I will run it for a hundred miles or so and then change it again while it is warmed up. The price of the wasted oil is still much cheaper than a new trans. BTW I love the difference the Red Line made in the sound & feel of my trans.
Ride Safe,
Mike
Old Mar 25, 2007 | 08:27 PM
Bryan TTM's Avatar
Bryan TTM
NOOOOO....GET IT AS HOT AS POSSIBLE...that way you can SCALD your pinkies when you change it
