Having Trouble Checking Shock Pressure
Old Apr 1, 2014 | 03:38 PM
RollaMo's Avatar
RollaMo
Originally Posted by bigheadted
Amazing how a little psst of air drops the pressure so much. Using the suspension pump and gauge loses almost nothing.
When there is only 4 or 5 "psst's" of air in there in the first place, it doesn't take much.
Old Apr 1, 2014 | 03:44 PM
Tripod2013's Avatar
Tripod2013
Then get yourself one of these to put it in, perfect fit. When I bought mine it was only 1pc, but 2 would be OK too!!
http://www.ebay.com/itm/2-each-Bank-...item3a7106d07b
Old Apr 1, 2014 | 10:31 PM
RollieB's Avatar
RollieB
Went through the same thing.Couldn't believe how little volume the shocks take.
Old Apr 2, 2014 | 04:58 AM
grbrown's Avatar
grbrown
We've been discussing this since the 1980s, when they were introduced! You have two choices, either buy the 'proper' gauge with dial (H-D or aftermarket), or get used to the simple fact that checking with a normal tyre gauge loses air. I've been setting my air suspension for over 20 years using a bicycle pump and tyre gauge, simply setting the pressures to take into account the loss.
With a little experience you will find that a certain pressure suits you when solo, perhaps another when 2-up. They may be quite different to other riders you meet. If you continue with what you currently have, simply get used to setting a pressure, as you have already.
Old Apr 2, 2014 | 05:03 AM
Iceman24's Avatar
Iceman24
Exactly, an ant farts enough air to fill your rear shock lines. Even though HD's gauge is $pendy, it's the best one I've used to check, fill & bleed air from the system.
jpooch00
2014-2024 Touring Models
19
Oct 22, 2016 09:14 PM
5x40
15
Sep 8, 2015 08:13 AM
C908
Jun 3, 2011 11:56 AM
bloozeman2002
Jun 1, 2009 01:41 PM
67xlch
Jan 1, 2008 08:38 PM
