Red key light on and it won't start
Old Apr 7, 2014 | 07:05 AM
  #31
Ickysticky74's Avatar
Ickysticky74
Originally Posted by Ickysticky74
I think the mileage comes on. I will have to verify tomorrow. The gauges come on.
The mileage comes on as well as the dash lights and gauges work. Grappling some fuses and relays after work. Hoping I can fix this.
Old Apr 7, 2014 | 07:34 AM
  #32
jdelange's Avatar
jdelange
Make sure the "key" is turned to ignition and not access. I've done that before...
Old Apr 7, 2014 | 09:00 AM
  #33
Ickysticky74
It's on ignition.
Old Apr 7, 2014 | 09:15 AM
  #34
COFLHTK's Avatar
COFLHTK
You have a blown relay. You should have two relays in the fuse panel. Im not sitting in front of the bike that I had this occur on, or I would tell you exactly which one it is. Swap the two relays and the red light should go off and the bike will turn over but wont start, because both relays have to be good. Either way, pull one of the relays out and go get a new one, I paid about $7 for it at Checker Auto Parts. Then go home and put the new one in.
Old Apr 7, 2014 | 09:28 AM
  #35
Riceman's Avatar
Riceman
Did you ever figure out how to retrieve your codes? It will give you the message on the mileage display. The codes maybe inhibiting you from starting it.
Old Apr 7, 2014 | 05:35 PM
  #36
sanman4ever's Avatar
sanman4ever
Any update?
Old Apr 7, 2014 | 06:18 PM
  #37
Ickysticky74
Ok I feel like an idiot. It was an ignition fuse. The old fuse looked good. Thanks everyone for their hints and advice. Boy do I feel stupid but I would rather feel stupid than have it not work.
Old Apr 7, 2014 | 06:36 PM
  #38
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
There...That's a lesson you won't soon forget.
Always remove a fuse from the circuit and test it electrically to be sure.
Glad you found the problem.
Old Apr 7, 2014 | 06:42 PM
  #39
mountain man's Avatar
mountain man
Now you try to figure out what caused it to blow!
Old Apr 7, 2014 | 06:43 PM
  #40
Ickysticky74
Thanks getting a volt meter tonight. It didn't start so I switched the brake relay out with the start relay and then it started right up. I bought relays but Harley gave me the wrong ones.
