frront brake
Old Apr 17, 2014 | 07:03 PM
oldtimer61's Avatar
oldtimer61
Default frront brake
Today using front brake and low speed the bike pulled to the left. The brakes are free no hang up it was like the brake was locking up on one side. any ideas
Old Apr 17, 2014 | 07:06 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Try this Service / Tech | Lyndall Brakes
Old Apr 17, 2014 | 07:32 PM
qtrracer's Avatar
qtrracer
Plenty of bikes and HD's only have disc's on 1 side on the front and they don't pull to one side or the other.
Old Apr 17, 2014 | 09:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the brakes won't cause it to pull,even if only one side was working it will stop straight unless your leaning or not dead straight when u hit em.
Old Apr 18, 2014 | 10:13 PM
Punjabi Rider's Avatar
Punjabi Rider
I would try it on different surfaces to see if it brakes suspension or some thing else.
Old Apr 18, 2014 | 10:26 PM
mkguitar's Avatar
mkguitar
don't know what you mean by low speed- define.
when i ride at 'low speed' like parking lots etc.
I'm pretty sure I'm gonna use my rear brake pretty much exclusively
mike
Old Apr 18, 2014 | 10:32 PM
dirtdobber's Avatar
dirtdobber
front brake during low speeds/gravel/sand does not work very well. Sounds like the front tire was locking up due to the surface.
If the surface has gravel lose rocks/sand Even just a little.
If you have not taken a riders course I suggest you think about it.
Old Dec 30, 2019 | 10:05 AM
RockerMike's Avatar
RockerMike
Somehow I ended up in the wrong thread.
Old Dec 31, 2019 | 08:27 AM
btsom's Avatar
btsom
My guess, not specifically brake related, two contributing causes. Harley front end design seems to cause a "turn tightening" force when the front wheel isn't straight ahead when braking, typically only noticeable at low speed. Second, you don't provide the mileage on your tires. As tires wear they begin to follow or react to ruts and longitudinal seams in the road. You will feel a wobble or the bike wanting to turn to go down the side of a rut. Applying the front brake on a seam or rut magnifies the reaction. Were you turning or on a seam when you noticed this?
Old Dec 31, 2019 | 12:50 PM
ronbeejer's Avatar
ronbeejer
Almost 6 years old...…...
