adjusting the handlebars
Old May 7, 2014 | 03:14 PM
KCFLHRC's Avatar
KCFLHRC
Originally Posted by sharpshooter
That is what I was thinking... So am I right in thinking I DONT have to remove the head light on my 12?
Correct, remove that plastic cover behind the handlebars and you will see the 2 Allen Bolts. That little cover just pops off.
Old May 7, 2014 | 03:15 PM
sharpshooter's Avatar
sharpshooter
Hell Ive been putting it off thinking it was gonna be a major ordeal lol
Old May 7, 2014 | 03:53 PM
mkguitar's Avatar
mkguitar
cut and paste of earlier post:
Originally Posted by mkguitar
We see posts once in awhile about the common tranny end cover coming loose and leaking. ( revised torque spec is now 25 ft lbs.)
Owners may be hesitant to tackle this as the manual says remove headers...what a PIA.
The alternative is to use another tool that is small enough to get in there- this also works for the handlebar clamps, which is what i was adjusting today.
A 1/4" drive screwdriver bit can be placed butt end first into the allen head and turned with a wrench.
if clearance is tight, just hacksaw a piece off of a 1/4" allen wrench. slip it into the allen and turn with a wrench.
Keep the stub with your other allens- I misplaced mine ( cause it's small) so i made another- I'll put a big piece of tape on this one
job done.
Mike
cover your tank with a thick towel, make sure you have at least 3/8" clearance when at full lock- the handlebars are on bushings and will move if leaned on, you don't want to scratch the tank
Old May 8, 2014 | 08:28 AM
hardheaded's Avatar
hardheaded
don't know about your 09, but my 12 had torx bolts in the handle bar clamp and they were tight and i mean really tight. no way i could get them loose so i just remove the radio and loosen the front bolt using a ratchet. not that big of a deal. if you do it this way you don't need to remove switch or the panel below it.
Runcy12
11
Sep 4, 2018 11:54 AM
rbm33
Apr 4, 2014 10:38 PM
jmn1960
Nov 7, 2012 03:57 PM
E.T.
Jul 15, 2012 12:39 AM
steelerdude1
Apr 22, 2011 01:40 AM
