Clutch cable rub
Old May 7, 2014 | 11:12 AM
reddog8145's Avatar
reddog8145
Default Clutch cable rub
Hi guys
I've just noticed that the clutch cable on my RKC has been rubbing against the front engine guard bars, causing scratches in the chrome.
It's not dramatic at this stage but has anyone else noticed this or is it that my cable has been routed incorrectly.
I've looked at how the cable could be moved to prevent contact with the top of the bar but that would put the cable on the other side of the front down tubes of the frame, bringing it close to the front cylinder.
My other idea is to make a soft leather guard, to wrap around the bar and protect the contact point. I would probably have to make two, one for the right side, just to even it up so it doesn't look odd.
Is there anything on the market like this or does anyone have any ideas.
I've put a strip of clear tape on the bar, to protect it at the moment while I make a decision on what to do.
The bikes only done 11000 miles and I don't want the chrome rubbing off leaving the nickel base showing
The cable rubs at the back of the bar, you can probably see it on the picture.
Any advice
Ride safe
Old May 7, 2014 | 11:26 AM
mkguitar's Avatar
mkguitar
no pic
whatever you do, do not restrict the natural movement of the cable with the bars.
we have had a couple of guys get the clutch cable snagged which kept the rider from steering the bike.
a cover on the cable or bar would work.
you could even slide a piece of clear heat shrink tubing over the clutch cable where it contacts the bar
mike
Old May 7, 2014 | 12:48 PM
MadIrish's Avatar
MadIrish
Same issue on my FLHR.....Haven't cared enuff to act...my solution would be a nice ring of black electrical tape with my vivid black bike, lol.
Old May 7, 2014 | 10:10 PM
FenderGuy53's Avatar
FenderGuy53
You can pick up a black plastic wire loom at the auto parts store for a couple of bucks. It's flexible and has slit that runs the entire length of the loom. Simply cut to size, then slip the cable into the loom via the slit. The loom closes around for cable for a nice, tidy fit.
PacBlue_07
Jun 9, 2019 11:25 AM
gnalen
Jul 31, 2017 01:31 PM
cmosentine
Mar 24, 2013 08:58 PM
Lightyear68
Dec 18, 2012 10:37 PM
skylee
Jul 15, 2010 08:48 PM
