Okay y'all, since my recent engine build on my 2009 FLHX, as you may guess I have been keyed in on the sounds my bike is making. I recently noticed a popping sound that appears to be coming through the air cleaner. Its got a high flow air cleaner which I have had on it for a few years (Zippers upgrade on stage 1 backing plate), but I didn't notice it before. Am I just hearing things that have always been there and its just more distinct now that the engine is moving more air? I can't really describe the sound other then it only really happens under a load, not lugging the bike but upon accelerating under a slight load in lower RPM range I seem to hear it more.
Am I going crazy and need to just double check everything again and ride it or has anybody else noticed this?
Not sure if touring or engine section was right place for this question, more people viewing this sections so I choose it.
What RPM are you talking about in your "lower RPM range"?
As far as lugging the motor, head wind, road grade, weight, and speed all have a factor.
I usually only ride in the 2500- 3200 RPM range, unless in the Rocky Mountains, then I can go higher. (low 4000)
2000 to 2500 rpms, lower end of the power band. The more I think about it the more I think it is just sucking more air and I am hearing things that I should be hearing.
The noise you are hearing may be the intake. Most intakes will make a noise due to the overlap of the cam popping against the throttle blades some are louder than others.
this is what I suspect too.
this can be reversion, exhaust pulses coming back up the tubes and through the cyclinder during the period when both valves are open ( esp with Carb, you'll smell fuel in the filter media).
changing the exhaust tract can tune this out, or move it to another rpm range.
it will be affected by any change in the length or diameter or restriction of the exhaust.
to test this: rev the bike to where it happens, get an assistant to put the sole of their boot partly over the end of the muffler. If it changes- then it is reversion
