Help, primary fluid
Old May 10, 2014 | 11:28 PM
Def Mute's Avatar
Def Mute
You can use almost any oil in the primary...
as long as there are no slip/friction modifiers, no detergents, and I wouldn't go above SAE 50W. Since you are in a northern state, where temps can get pretty low, you can use a multi-viscosity oil also. You could even use ATF Type F. But, it is recommended by many manufacturers to NOT use Dexron/Mercon ATF. Many people use synthetic oil(s) even. Primary oil is mostly used for oiling the chain, and prolonging the life of the clutch disks.
Old May 11, 2014 | 12:54 AM
skratch's Avatar
skratch
Originally Posted by risuperglidecustomman
Go to Wally World & get some Shell Rotella 10W-40. It will work great!
Originally Posted by TUCCI
Yup, I've been using the T6 for quit some time and it's the smoothest. Tried many variations and the least noisy is the Rotella....I change mine out every 2k on both our bikes.
Originally Posted by skiddd
I'm gonna try Rotella next primary change........... keep reading about here.
been using it for a few years. i don't change it out every 2k, but i do change it with every engine oil change (5k) my cvo doesn't have a clutch adjustment since it has a hydraulic clutch, but on my old bike i would do a clutch adjustment first, then ride the bike to get the oil hot and then do an engine and primary change. always made the bike feel like a new bike
also, the rotella is jaso rated for wet clutch use, and can be had for about $13.00 a gallon. which is enough for 3+ changes.
Old May 11, 2014 | 06:23 AM
nickd23's Avatar
nickd23
Completed this last night, lost a very small amount at first so used a little of the new oil but worked great and looks amazing! Thanks for the help
Old May 11, 2014 | 09:55 AM
hardheaded's Avatar
hardheaded
Originally Posted by EG-2006
I'd put the old oil back in it but if you buy new oil make sure its motorcycle rated. Thats your clutch in there and it needs motorcycle rated oil. I use Mobile 1 V Twin oil
TriGeezer
Oil Archive (no new posts)
Apr 20, 2016 04:22 PM
big TYME
May 10, 2012 10:20 PM
RZA
Jan 26, 2012 05:22 AM
jmcollison
May 15, 2009 07:03 PM
Gary7
Feb 22, 2009 02:06 PM
