You backed preload off 6mm, and handling went from "too rigid" to "a little wobbly"? Something's not right here. I agree w/ SEL53 in that your spring rate is too high (as usual for Ohlins). I use a 25N/mm spring and by myself, it's a little firm, but w/ a passenger on back, it's perfect. It's set at an initial preloaded length of about 200mm. You really need to check your sag measurements and make corrections from there.
I find it hard to believe that you have to adjust the spring length??
Do you mean adjusting the collars which help adjust the sag?
If so you are not adjusting the spring length.
As stated about 1/3 of the overall length from eye to eye is what it should sag when you sit on it fully vs just the weight of the bike
Yes sorry your right about that, its the sag i'm adjusting. I weigh in at 238 lbs and have read that a chap who weighs about the same uses 32NM springs. Don't know how he gets on with it but he's happy
OK! been out to the workshop, and adjusted the springs so I got 295mm spring length as a starting point.
Next measured the sag and as you all know, very little movement, think is was around the 5mm if I was lucky. Still in the Ohlins spec but they are way too stiff as you all been telling me.
Now sat on the bike and didn't even notice a drop when perched in the saddle, so have emailed my supplier as they assured me that the springs would be perfect for my weight.
Ohlin's instructions should tell you what the total travel of the shock is and you should set rider sag for 1/3 of that. My JRis were about 90mm so I set it at 60 or 30 less than full extension. Make sure you take several measurements to overcome "sticktion", which is a made up word describing the force required to overcome the friction lock in the damper. There are some great articles on line to help you learn more about suspension. It's probably the least understood component of a vehicle yet it's the most significant for maximizing safety, comfort and lap times.
You should get at least 10mm more sag when you sit on the bike than when it is just sitting on its wheels. This is a very good measure of whether the spring rates are right.
For your weight I would recommend a 25N/mm spring rate. Ohlins has one in the right diameter that has the 220mm length like your current one. It is the 00180-79/25. Looks like it only comes in yellow, but you could ask if they have black (don't let that stop you from getting the right rate). They also have a black one in that rate that is 200mm long, which I also suspect will work with your shock. It is the 00280-21/25.
That rate should work very well for you both solo and with passenger.
Thanks Sel53 for the info, I got a reply from the shop and they say its the one that Ohlins recommend for my bike and it will have too much sag if I use another softer spring. But they are willing to exchange. I will let them know of the spring I require, funny though as the spring I originaly requested is in yellow. Ohlins colour for me!
But they are willing to exchange. I will let them know of the spring I require ...
That's great that they will work with you. I don't know about Ohlins overseas, but Ohlins USA motorcycle guys are very helpful, and will give you their opinion as well. If you call them, Matt was pretty dang helpful for me.
Let us know how it works out, and what spring you choose.
sl
