Problem with security system
Old May 13, 2014 | 02:42 PM
dyna07custom's Avatar
dyna07custom
I think you activated the hazards
Old May 13, 2014 | 02:49 PM
RollaMo's Avatar
RollaMo
Originally Posted by ke5rbd
there is an app for Android "V-Twin Reference" that has lots of info on how to do stuff on bikes, pin reset, enter pin, find pin, diagnostics codes and much more. Very handy. May have it for I Phone now.
The OP reported he does not have a FOB.
Without an active FOB, you are not going to reset or read any security pin.
Most of us don't believe he actually has a factory security system installed, since he was able to start the bike and ride away to begin with.
Your not going to do that with the factory security system and a missing FOB.
Old May 13, 2014 | 02:53 PM
RollaMo's Avatar
RollaMo
That would explain why they don't shut off after 30 - 45 seconds.
The hazards would keep running until you either shut them off, pulled the fuse, or the battery died.
Even though the factory security system uses the turn signals when the bike is disturbed, it does so in an alternating pattern (left, right, left, right, left, right), not both at the same time.
It would also stop flashing after 30 - 45 seconds.
Old May 14, 2014 | 06:16 AM
skratch's Avatar
skratch
i said that way back....
i wish the op would come back and let us know what happened.
Old May 14, 2014 | 09:38 AM
zdrifter's Avatar
zdrifter
No longer available ................ too bad as it sounds handy, but you can pdf the stuff from your manual onto your phone to get to the same end ...........
wparente
Nov 16, 2015 04:27 PM
Rackenhack
Nov 10, 2013 03:29 PM
Tri Glide
Nov 7, 2012 07:11 AM
Hawgin
Sep 4, 2012 07:49 PM
Chicago Spike
General Topics/Tech Tips
Nov 17, 2008 10:24 AM
